Zabbix discover finding shutdown systems
  • cjbidwell
    • Dec 2019
    • 16
    Hi all,
    So my discovery agent runs to search for systems within various subnets that see the zabbix agent responding to. Seems clear enough.
    If I shutdown a server/workstation and remove that system from inventory, it pops back up again even though the server is still shutdown.
    How can I prevent shutdown systems from reappearing again?
    Thanks!
  • provels
    • Apr 2020
    • 93
    Just a wild guess, as I know nothing about anything. That said...
    Could it be because Wake-on-LAN is enabled on those NICs?
    • cjbidwell
      • Dec 2019
      • 16
      Heh, I thought about that, but it also applies to VM's that I've completely deleted from the hypervisor. Strange huh?
      • provels
        • Apr 2020
        • 93
        Guess you could try disconnecting them from the LAN and scanning again. Maybe they're cached entries in DNS?
        • cjbidwell
          • Dec 2019
          • 16
          So I added an icmp check along with a zabbix agent check. In testing, I cannot ping this system, so it's wake-on LAN is not enabled in that sense. We'll how this goes. Thanks all.
          • cjbidwell
            • Dec 2019
            • 16
            Well, that didn't seem to do anything. I delete the host, and after about an hour, it just reappears again. Hmm...Any ideas folks?
            • Hamardaban
              Hamardaban commented
              If you delete the host created during the discovery process, it will appear again because it is associated with the discovery.
          • cjbidwell
            • Dec 2019
            • 16
            I did what you mentioned and disabled my discover processes and actions, removed them, waited for an hour and reenabled and they still seemed be showing back up.
            • cjbidwell
              • Dec 2019
              • 16
              Any other ideas? So now I have a workstation that I moved the DNS (using IP for discovory) from one IP to a different and shutdown the workstation with the old IP. It's still finding the old IP even after I've deleted it from config -> hosts.
              • provels
                • Apr 2020
                • 93
                ARP cache on an intermediate switch?
