server no running
  • nikohal
    • Apr 2015
    • 24
    server no running
    In web page says Zabbix server is not running:....
    How to fix this?
    But server running...
    zabbix 4580 1 0 09:06 ? 00:00:00 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
    root 11668 4787 0 11:24 pts/1 00:00:00 grep --color=auto zabbix
  • Kamalesh
    • Oct 2015
    "Zabbix server is not running: the information displayed may not be current"
    Hi Nikohal,
    Hope you are doing good!
    I am also facing similar issue with Zabbix 2.4.1 appliance. Did you find any resolution? If yes, please share, it will be a great help
    Thank you!
    • LenR
      • Sep 2009
      • 1011
      check the zabbix server log, but my first guess is that the server can't connect to the database.
      • neogan
        • Sep 2011
        • 118
        Hi All,
        Hope you have alredy found the solution.
        This happens when web frontend cannot connect to zabbix server by trapper protocol, there are several cases:
        - selinux not alowed to connect httpd to zabbix (check your audit log)
        - zabbix server not runing. (but I think you've checked this alredy.)
        So I think it is SELinux. Here is the commands which might help
        [root@local]# getsebool httpd_can_network_connect
        httpd_can_network_connect --> off
        [root@local]#setsebool httpd_can_network_connect on
