I have an item ( Type of information : text ) which receives 5 different values each in MB
I have 3 dependent items( Type of information : float ) each storing 1 value.
My problem is if I apply a custom multiplier to convert MB to B and use item unit as B so that in the graph it gets auto-displayed as B, KB, MB, GB, however many times the pre-processed value is more than what zabbix allows in float item type range.
For example
item that store the string has value:
Folder space 1(in MB) : 345
Folder space 2(in MB) : 10282
Folder space 3(in MB) : 1029471
For the dependent items :
To convert to Bytes I add a pre-processing of custom multiplier of value*1024*1024. Many times I get error that it is out of range.
I can't use M in unit cause in the graph it then shows MM which should actually show TB.
For example
