SNMP2 & commvault error, MIB + convert to Zabbix Template
  • GreenHorn
    • Nov 2020
    • 54
    Hello folks,
    I am a new in Zabbix/monitoring . I need monitor the commvault system on Microsoft 2019. I can't find some MIB file with OID for commvault. So I am trying find OID via snmpwalk -v2c -c public ​*domain.name* .1. I am using DN for differeding of Commvault and OS. But when is command runnig
    1) I get this error:
    SNMPv2-SMI::enterprises.77.1.1.1.0 = STRING: "10"
    SNMPv2-SMI::enterprises.77.1.1.2.0 = STRING: "0"
    SNMPv2-SMI::enterprises.77.1.1.3.0 = Hex-STRING: 07 00 00 00
    Error in packet.
    Reason: (genError) A general failure occured
    Failed object: SNMPv2-SMI::enterprises.77.1.1.3.0
    Is there someone with experience with this?
    2) I need monitor from backup system (commvault) these parts via snmp:
    • File system capacity(backed up & stored)
    • File system efficienty( compression factor)
    • CPU usage
    • NVRAM usage
    • ENvironmental (for example: power, temperature, fan)
    • replication lag time status
    • retention period
    • backup software
    • the archive software success status od archive jobs from the master server
    • The status of the infrastucture servers which make up the nevironment
    3)Do you know , how convert MIB as Template for zabbix?
    Thank you for any idea or steps.
