PHP always_populate_raw_post_data failure
  • floydmulder
    • May 2015
    I had a previous installation of Zabbix on my server that worked fine, but I've had to reinstall pretty much everything since I updated Ubuntu to 15.04. After installing the frontend and running the installation through the web GUI, this one particular prerequisite keeps failing. Zabbix insists that always_populate_raw_post_data be set to -1 (off). I've looked in /etc/php5/apache2/php.ini, and it's already set to -1. I've tried adjusting this every way I can think of to get a different result (and restarted Apache2 each time), and nothing I do seems to allow it to pass. To be completely fair, I'm pretty new to Linux and PHP, so it's entirely possible the problem isn't anything more than me being an idiot. Has anybody ever run into this problem before, or know how to remedy it?
  • floydmulder
    • May 2015
    ...and, yeah, I am an idiot. Forgot to take the quotes off. Problem solved!
    • Jay Liu
      • Jul 2015
      I have same problem. How did you fix it? Thanks.
      • Atsushi
        • Aug 2013
        • 2028
        Please try modify that php.ini. (take the quotes off)
        ;always_populate_raw_post_data = -1
        to:
        • apeyrot
          • Aug 2015
          php 7.
          In php 7 this line has been remove
          always_populate_raw_post_data "0" PHP_INI_PERDIR PHP_INI_ALL in PHP <= 4.2.3. Available since PHP 4.1.0. Removed in PHP 7.0.
          Does anyone has found a workaround?
          Thank you.
          • apeyrot
            • Aug 2015
            Found the solution.
            I will leave here this, it's the workaround I found.
            In the file CFrontendSetup.php. This file is in /usr/share/zabbix/include/classes/setup/
            In this file we have to change the value of the version of PHP
            Original code
            // check for deprecated PHP 5.6.0 option 'always_populate_raw_post_data'
            if (version_compare(PHP_VERSION, '[B]5.6[/B]', '>=')) {
                     $result[] = $this->checkPhpAlwaysPopulateRawPostData();
            After making the change
            if (version_compare(PHP_VERSION, '[B]7.1[/B]', '>=')) {
            And thats all. I have to restart my browser and launch again the setup wizzard.
            • dnoe
              • May 2016
              Just found this thread helpful, a year after it was posted. Thanks apeyrot!
              Original code
              • wilepro
                • Sep 2016
                thanks
                thanks for this solution
