Digital Signed Certificate need to attach with zabbix port 37000
  • noor
    • Dec 2020
    I am using Zabbix 5.0.6 on Ubuntu 20.04 on http port 80
    i have purchased certificate for my domain zabbix.mydomain.com and want to attach with my zabbix server with port 37000 instead of 443.
    can anyone guide me how i can do step by step to get it done
    i will be very thankful.
    Regards,
    Noor.
  • Hamardaban
    • May 2019
    • 2714
    This is a matter of setting up the web server you are using, not Zabbix. Determine which web server you are using and Google how to change the port and configure https exactly for your case.
    • noor
      • Dec 2020
      yes i did it and successfully installed my certificate with Apache2.
      now second issue is still pending that i want to change 443 into 37000 can you please advise any reference how i can do that.
      • noor
        • Dec 2020
        Thanks for your reply as i did it via reverse proxy configurations.
        Regards,
        • Hamardaban
          • May 2019
          • 2714
