Zabbix remote command problem
  • vinidarlo74
    • Dec 2020
    I have two triggers that execute a remote command, but It is executing the command twice. How can I specify to only run the command once?
    As you can see each trigger execute the remote command.192.168.0.1 routerlogin 192.168.l.l
  • Hamardaban
    • May 2019
    • 2714
    If the action refers to 2 triggers, keep in mind that the simultaneous triggering of triggers is not tracked. Make a dependency of one trigger on another-then the action will be one time.
