How to connect Windows as an ACTIVE agent
  • GRIFFCOMM
    • Jan 2021
    • 11
    Hi
    We have tried to connect a Windows agent as ACTIVE (there-by reaching out to the servers port 10051 and pushing data to the server), cant get it to work.... unable to find any settings on install to make it work either, ANY IP address used goes in to the PASSIVE server setting. When over ridding this in the conf it windows server will not start.
    So how do we connect a Windows server to a Zabbix server via ACTIVE and not passive?
    Many Thanks
    • 4996
    Just as on any other platform, by setting additional "ServerActive" parameter with your proxy/server address, where your agent has to turn to get its config... No special installtime option for that.
    Don't forget, you need both "Server" and "ServerActive" for active checks.
    Its all here, in docs, as usual https://www.zabbix.com/documentation...bix_agentd_win
