mqtt.get item problem
  • karol.k
    • Jan 2021
    Hi, I can't find similar problem here
    I want to add zabbix agent active item mqtt.get and I have message "Incorrect update interval". When I want to edit item I can't see this field. It's interesting, when I select another key, for example modbus, the Update Interval field displays, when I select mqtt again it doesn’t display.
    I've installed 5.2.1 version on debian from repo.
  • Atsushi
    • Aug 2013
    • 2028
    Have you selected 'Zabbix agent (active)' as the item type?
    • karol.k
      • Jan 2021
      Yes, but I resolved this, I had to install zabbix-agent2 on my broker. Thanks for reply
