I am trying to figure out follow issue. I have client monitored via zabbix proxy but cannot obtain values from Active checks.
What I currently have:
1. Items (active) are created in the Zabbix GUI
2. Hostname match Zabbix server and client configuration - part of the tcpdump: (ZBXD.0.......{"request":"active checks","host":"myhostname"}
3. Server/proxy response with list of the items for the client : again small part from tcpdump: response":"success","data":[{"key": ........
4. Client doesn't provide any values - connection is Reset - IP X.X.X.X.53064 > proxy.10051: Flags [R],
In log file I have only follow error: active check configuration update from [X.X.X.X:10051] started to fail (ZBX_TCP_READ() timed out)
When I increased debug level follow was reported: End of refresh_active_checks():FAIL
Telnet on port 10051 works fine from client to proxy.
Any idea what I could check to fix it?
Thank you.
Thank you.
