I tried installing a fresh Zabbix 5.2 with Pg12 and TimescaleDB on Debian 10. All is working fine, I can get a nice running Zabbix 5.2 serrver, then the problem is that if I enable TimescaleDB I get errors on zabbix_server.log:
If I disable the compression on the Housekeeping page I get only:
The error is the same on Pg11 and Pg12, if I enable TimescaleDB on install or after I have a functional zabbix setup.
If I do this all starts to fail:
These are the installed packaged:
Thank you,
Rares
[Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "_timescaledb_config.bgw_policy_compress_chunk s" does not exist
LINE 1: select (p.older_than).integer_interval from _timescaledb_con...
[select (p.older_than).integer_interval from _timescaledb_config.bgw_policy_compress_chunks p inner join _timescaledb_catalog.hypertable h on (h.id = p.hypertable_id) where h.table_name='history']
579:20210108:123321.870 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: function add_compress_chunks_policy(unknown, integer) does not exist
LINE 1: select add_compress_chunks_policy('history', integer '612000...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
[select add_compress_chunks_policy('history', integer '612000')]
579:20210108:123321.870 failed to add compression policy to table 'history'
579:20210108:123321.873 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "_timescaledb_config.bgw_policy_compress_chunk s" does not exist
[select (p.older_than).integer_interval from _timescaledb_config.bgw_policy_compress_chunks p inner join _timescaledb_catalog.hypertable h on (h.id = p.hypertable_id) where h.table_name='history_uint']
579:20210108:123321.874 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: function add_compress_chunks_policy(unknown, integer) does not exist
LINE 1: select add_compress_chunks_policy('history_uint', integer '6...
[select add_compress_chunks_policy('history_uint', integer '612000')]
579:20210108:123321.874 failed to add compression policy to table 'history_uint'
[Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "_timescaledb_config.bgw_policy_compress_chunk s" does not exist LINE 1: select (p.older_than).integer_interval from _timescaledb_con... ^ [select (p.older_than).integer_interval from _timescaledb_config.bgw_policy_compress_chunks p inner join _timescaledb_catalog.hypertable h on (h.id = p.hypertable_id) where h.table_name='history'] 963:20210108:123924.963 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "_timescaledb_config.bgw_policy_compress_chunk s" does not exist LINE 1: select (p.older_than).integer_interval from _timescaledb_con... ^ [select (p.older_than).integer_interval from _timescaledb_config.bgw_policy_compress_chunks p inner join _timescaledb_catalog.hypertable h on (h.id = p.hypertable_id) where h.table_name='history_uint']
service zabbix-server stop echo "CREATE EXTENSION IF NOT EXISTS timescaledb CASCADE;" | sudo -u postgres psql zabbix cat /usr/share/doc/zabbix-server-pgsql*/timescaledb.sql | sudo -u zabbix psql zabbi service zabbix-server start
zabbix-agent 1:5.2.3-1+debian10 amd64 Zabbix network monitoring solution - agent zabbix-apache-conf 1:5.2.3-1+debian10 all Zabbix network monitoring solution - apache configuration for front-end zabbix-frontend-php 1:5.2.3-1+debian10 all Zabbix network monitoring solution - PHP front-end zabbix-release 1:5.2-1+debian10 all Zabbix official repository configuration zabbix-server-pgsql 1:5.2.3-1+debian10 amd64 Zabbix network monitoring solution - server (PostgreSQL) postgresql-12 12.5-1.pgdg100+1 amd64 object-relational SQL database, version 12 server postgresql-client-12 12.5-1.pgdg100+1 amd64 front-end programs for PostgreSQL 12 postgresql-client-common 223.pgdg100+1 all manager for multiple PostgreSQL client versions postgresql-common 223.pgdg100+1 all PostgreSQL database-cluster manager postgresql-server-dev-12 12.5-1.pgdg100+1 amd64 development files for PostgreSQL 12 server-side programming timescaledb-2-loader-postgresql-12 2.0.0-zz~debian10 amd64 The loader for TimescaleDB to load individual versions. timescaledb-2-postgresql-12 2.0.0-zz~debian10 amd64 An open-source time-series database based on PostgreSQL, as an extension.
Rares
