Unsupported key error in Low Level Discovery alert
  • zabbix_tester
    • Jan 2021
    I'm trying to setup a simple low level discovery alert, but it's complaining unsupported key (system.run) on low level discovery, I will show my setup as below:
    system.run[cat /etc/zabbix/ipactl.txt]
    I ran a test and the result returned, I have a script setup and whenever it runs in background it will trigger 0 or 1 value to the text file, but apparently whenever I try to get it setup as a low level discovery alert and it will say "Unsupported key" as an error
    I already have add AllowKey=system.run[*] and EnableRemoteCommands=1 in the Zabbix Agent config file and restarted the services.
    I've also checked the log file and didn't find any suspicious error message. Can any of you suggest what will be the solution for this?
    Thanks,
    Zabbix_tester
