Unattended Agent installation with multiple 'tlsaccept' parameters
  • hesi2k
    • Jan 2021
    Hello there,
    I would like to ask you a question about unattended agent installation with multiple tlsaccept parameters.
    If I understand it correct, the Zabbix Network Discovery needs an unencrypted connection between (Server/Proxy and the Agent) to discover them correctly.
    In my scenario i got a cloud hosted Zabbix server and a Zabbix proxy on premise incl. several agents installed (all version 5.0.7).
    I configured a simple discovery rule for the on premise network range with the check "Zabbix Agent 'system.hostname'".
    I installed the windows agents with the following parameters: SERVER=<IP> TLSACCEPT="unencrypted, psk" TLSCONNECT=psk TLSPSKIDENTITY=<ID> TLSPSKVALUE=<PSKVALUE> HostMetadata=WindowsServer
    When I check the agent config file I will find TLSAccept=psk only without "unencrypted" and no agent will be discovered.
    After manually changing the config file to a comma seperated value TLSAccept=psk,unencrypted the discovery starts to find the agents.
    My simple question is, how to install the agent with the specific comma separeted value?
    Thanks in advance :-)
    Hesi
