Zabbix AD Integration
  • sajid4uu2c
    • Oct 2020
    • 24
    Hi Team,
    I have assigned all the parameters as suggested in the Zabbix LDAP integration . Still I am getting the error like "Cannot bind to LDAP server."
    Attached the screen grab for the same. Kindly help.
    Zabbix version is : 5.0.5
Name:	AD Error.png
    Note: I do not have any ldap packages installed in my Zabbix server( RHEL 8 )
    So, I cannot run ldapsearch or find any logs. Is it mandatory to install ? Please suggest.
  • Kos
    • Aug 2015
    • 3469
    I believe that Web-interface authentication is performed by a web-server; therefore you need to be sure that:
    • the package php-ldap (probably, php7-ldap) in installed on computer with the web-server;
    • the communication between your web-server and domain controller (TCP port 389) is not blocked by any firewall;
    • domain controller allows to process non-encrypted LDAP requests. Usually it is a security risk, so admins allow LDAPS (tcp port 636) connections only.
    Some additional notes:
    • if you use an encrypted connections (LDAPS) and your DC uses a self-signed certificate, you will need to add a parameter "TLS_REQCERT allow" to the ldap.conf file (probably, /etc/openldap/ldap.conf) of your computer with web-server;
    • take into account that LDAP username (used in "Bind DN" field) uses the Display name (instead of sAMAccountName, a.k.a login name) of the user.
    • sajid4uu2c
      • Oct 2020
      • 24
      Thanks Kos I have followed as suggested and able to successfully authenticate LDAP.
