Zabbix reverse proxy with nginx
  • tursadilar
    • Jan 2021
    i try to reach my zabbix 5.0.7 server behind a nginx reverse proxy. Login Screen is loading, but after login i get a blank white site.
    nginx reverse proxy setup: External address: https://mydomain.com/monitor
    location /monitor/ {
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Server $host;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_pass http://ip/monitor/;
    Setup Nginx Webserver (simple setup to test reverse proxy),
    /usr/share/zabbix is linked to /var/www/html/monitor
    server {
        listen 80;
        server_name ip;
        root /var/www/html;
        location ~ \.php$ {
        include snippets/fastcgi-php.conf;
        # With php-fpm (or other unix sockets):
        fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
    internal access with login is ok: http://ip/monitor.
    I am grateful for any help. Thanks
    Tursadilar
