Zabbix Active Agent Not Updating Availability
  • Parasin
    • Dec 2014
    • 53
    Hi all,
    I recently began monitoring a Windows Host and it is utilizing all active checks. Normally when using passive checks, once your host retrieves the value for the
    agent.ping
    item, Zabbix automatically updates the host availability.
    With my Windows host using active checks, I am getting data from the agent and
    agent.ping
    is returning
    Up (1)
    But the availability is all grayed out still after ~ 1 hour! Zabbix server logs are showing all good, as well as Zabbix Agent logs.
    Is this a bug with Zabbix, or does active agent not change the availability status on the host list?
    ** NOTES ON ATTACHMENTS: First picture is expected result. Second picture is the actual result from my active agent host **
  • bbrendon
    • Sep 2005
    • 873
    Originally posted by Parasin
    Hi all,
    agent.ping
    agent.ping
    is returning
    Up (1)
    Yours is working correctly. The availability column should probably be removed. It's pretty useless. I've never paid any attention to that column. Just watch your dashboard and active triggers for availability.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • bbrendon
      • Sep 2005
      • 873
      Also, I'm not even sure what good agent.ping is as well. What's the point when you return CPU info from the agent to also ping it?
      I never understood myself. I've never used agent.ping either.
      • Parasin
        • Dec 2014
        • 53
        Brendon,
        Thanks for your replies! You bring up a good point regarding the lack of necessity for agent.ping!
        The only reason that I even care about showing the availability is that in my Zabbix installation I monitor hosts for other departments, whose owners sometimes like to login and see the status of their environments. So not having the availability update for this specific production environment could raise some questions from them.
        While this isn't a big deal; I have the data to show and the proper triggers established, my over-arching question is: Why doesn't the availability update when using active checks?
        Also, I checked out your blog! Really cool site and plan on reading more content on it.
        • bbrendon
          • Sep 2005
          • 873
          Good luck. It never has and likely never will. If you want the answer, you'll probably have to dig into the source code. Its probably the same reason why actions can't run commands with active checks.
          My suggestion to you is to edit the PHP front-end and remove that column from your mind.
