Zabbix and Telegram
  • Maxz
    • May 2015
    Zabbix and Telegram
    Hello.
    I have this telegram.sh
    PHP Code:
    #!/bin/bash
    export to=$1;
    export subject=$2;
    export body=$3;
    bin/telegram-cli -W -U $USER -e "msg $to $subject $body" > /dev/null
    exit
    If i execute this script from console, script successful work, but i add this script to zabbix, and want send messages from zabbix to telegram.
    That not work.
    I newbie in zabbix, if i can debug it. It must be useful.
    Thank you for any help.
  • Atsushi
    • Aug 2013
    • 2028
    Please try write full path of telegram-cli in that script.
    • Maxz
      • May 2015
      Sure man. This is of part of script.
      Full script that:
      PHP Code:
      #!/bin/bash
      export to=$1;
      export subject=$2;
      export body=$3;
      tgpath=/home/telegram/tg
      cd
      ${tgpath}
      exit
      • Atsushi
        • Aug 2013
        • 2028
        Can you change directory to that directory(/home/telegram/tg) by zabbix user?
        The script and command are can execute by zabbix user?
        ex. execute commands by zabbix user
        # sudo -u zabbix <script name> <args>
        • Maxz
          • May 2015
          Sure man. I can execute script from zabbix user and works correctly.
          • Atsushi
            • Aug 2013
            • 2028
            Have you set how and where to you as the setting of zabbix?
            Are you a registered telegram.sh as media?
            Do you have telegram.sh in the specified directory in AlertScriptsPath?
            Do not have been something in the log of Zabbix server?
            • Maxz
              • May 2015
              Zabbix settings and telegram ok.
              DebugLevel = 4
              I send any differnt way, from email and from telegram-cli.
              In a email message sent correctly.
              I cant find where and how have to look messages about sending emails or another script media.
              • Colttt
                • Mar 2009
                • 878
                if you have debug level 4; what say the log if zabbix-server run that script?
                Debian-User
                Sorry for my bad english
                • Maxz
                  • May 2015
                  Tell this :
                  PHP Code:
                  root@XX:/usr/share/zabbix/alertscripts# tailf /var/log/zabbix_server.log | tee /tmp/telegram_debug.log | grep -ni telegram
                  3622: 13132:20150525:053047.925 In zbx_popen() command:'/usr/share/zabbix/alertscripts/telegram.sh "user#98764128" "Problem" "Problem"'
                  3628: 13132:20150525:053047.933 telegram.sh output:
                  3630:Telegram-cli version 1.3.1, Copyright (C) 2013-2015 Vitaly Valtman
                  3631
                  :Telegram-cli comes with ABSOLUTELY NO WARRANTY; for details type `show_license'.
                  3634:Telegram-cli uses libtgl version 2.0.1
                  3635:I: config dir=[/root/.telegram-cli]
                  3636:I: config_file=[/root/.telegram-cli/config]
                  7225: 13141:20150525:053202.449 In substitute_simple_macros() data:'/usr/share/zabbix/alertscripts/telegram.sh user#98764128 Hello'
                  7227: 13141:20150525:053202.449 In zbx_popen() command:'/usr/share/zabbix/alertscripts/telegram.sh user#98764128 Hello'
                  7238: 13141:20150525:053202.460 query [txnlev:1] [insert into alerts (alertid,actionid,eventid,clock,message,status,error,esc_step,alerttype) values (135,8,988,1432531922,':/usr/share/zabbix/alertscripts/telegram.sh user#98764128 Hello',1,'',1,1);
                  8012: 13132:20150525:053217.950 In zbx_popen() command:'/usr/share/zabbix/alertscripts/telegram.sh "user#98764128" "Problem" "Problem"'
                  8018: 13132:20150525:053217.962 telegram.sh output:
                  8020:Telegram-cli version 1.3.1, Copyright (C) 2013-2015 Vitaly Valtman
                  8021:Telegram-cli comes with ABSOLUTELY NO WARRANTY; for details type
                  `show_license'.
                  8024:Telegram-cli uses libtgl version 2.0.1
                  8025:I: config dir=[/root/.telegram-cli]
                  8026:I: config_file=[/root/.telegram-cli/config]
                  • Atsushi
                    • Aug 2013
                    • 2028
                    Please show me more detail log.
                    you do not remove the information by grep so might contain important information.
                    • Maxz
                      • May 2015
                      Thank you man.
                      I resolve problem with this guide.
                      • TripleX
                        • Mar 2016
                        Question images/charts
                        i got everything up and running like a charm
                        error messages are coming in nicely incl last value etc.
                        however now i want to add images and then "automaticly" nothings gets pushed anymore
                        "Last value: {ITEM.LASTVALUE1} ({TIME})
                        zbxtg;graphs
                        zbxtg;graphs_period=10800
                        zbxtg;itemid:{ITEM.ID1}
                        zbxtg;title:{HOST.HOST} - {TRIGGER.NAME}"
                        when i do it from the command prompt
                        ./zbxtg.py xxxxx "test" "$(echo -e 'zbxtg;graphs: \nzbxtg;graphs_period=3600\nzbxtg;itemid:560\nzbxt g;titlelolo')"
                        Traceback (most recent call last):
                        File "./zbxtg.py", line 398, in <module>
                        main()
                        File "./zbxtg.py", line 380, in main
                        zbx.login()
                        File "./zbxtg.py", line 125, in login
                        requests.packages.urllib3.disable_warnings()
                        AttributeError: 'module' object has no attribute 'packages'
                        what am i doing wrong?
                        • Colttt
                          • Mar 2009
                          • 878
                          please try zbxtg.sh instead of zbxtg.py
                          Debian-User
                          • TripleX
                            • Mar 2016
                            Thanx for the reply..
                            i changed the tg_vars.cfg
                            i ran the zbxtg.sh also made it chmod a+x
                            then basiscly ran the same command as with .py
                            however zbxtg.py --debug gave result
                            zbxtg.sh --debug was blanc
                            also without --debug blanc
                            the debug was also set in de log file for .py but not for the .sh file..
                            I have to dig in deeper tonight...
                            • TripleX
                              • Mar 2016
                              Got it working
                              i got the error message " in private"
                              and went into telegram and sent bot a message /start
                              and i got the message in telegram inc the "url"
