Zabbix on Raspberry pi 4
  • dade
    • Jan 2021
    • 34
    Hello guys,
    I'm trying to deploy Zabbix on my Raspberry Pi 4, but i can't import zabbix schemas to MariaDB. I used the command "zcat /usr/share/doc/zabbix-server-mysql*/create.sql.gz | mysql -uzabbix -p'zabbixDBpass' zabbix" and it never finish. I waited for 9 hours and nothing, it just processing yet.
    How i can solve this ?
    notes:
    Raspberry pi 4, 4g ram
    32gb Sd card
    Zabbix-server and MariaDB are installed on same raspberry
    i have this configuration on my /etc/mysql/mariadb.conf.d/10_my_tweaks.cnf:
    [mysqld]
    max_connections = 454
    innodb_buffer_pool_size = 1G (ps. i have already tested with 400m too )
    innodb-log-file-size = 128M
    innodb-log-buffer-size = 128M
    innodb-file-per-table = 1
    innodb_buffer_pool_instances = 8
    innodb_old_blocks_time = 1000
    innodb_stats_on_metadata = off
    innodb-flush-method = O_DIRECT
    innodb-log-files-in-group = 2
    innodb-flush-log-at-trx-commit = 2
    tmp-table-size = 96M
    max-heap-table-size = 96M
    open_files_limit = 65535
    max_connect_errors = 1000000
    connect_timeout = 60
    wait_timeout = 28800
    thanks!
  • Hamardaban
    • May 2019
    • 2714
    Unpack the «create.sql.gz» file. The «create.sql» text file contains SQL commands. Connect to your database (mysql -uzabbix -p'zabbixDBpass' zabbix) and try to execute these commands sequentially.
    • dade
      • Jan 2021
      • 34
      Thanks for your reply, i ll test it
      • Imelda
        • Feb 2021
        I’m trying to figure out if there is a way to use macros for the SNMP context and both passwords? I know I can setup some global macros or template specific macros, What I’m trying to accomplish is to auto populate the SNMPv3 values with the macros I created? I hope this makes sense and I don’t even know if it’s possible Prepaid Card Status
        • dade
          • Jan 2021
          • 34
          So, Hamardaban, i tried what you said but it didnt work. =(
          • Ondricka
            • Feb 2021
            To follow this article, you will need the following things to set up your Raspberry Pi 4 in headless mode:
            1. A Raspberry Pi 4 single-board computer
            2. A USB Type-C power adapter
            3. A 16 GB or higher capacity microSD card with Raspberry Pi OS flashed
            4. Network connectivity on the Raspberry Pi 4
            5. A laptop or a desktop computer for VNC remote desktop access to the Raspberry Pi 4
            If you don’t want to set up your Raspberry Pi 4 in headless mode, you will also need:
            1. A monitor
            2. An HDMI or micro-HDMI cable
            3. A keyboard
            4. A mouse
            5. KrogerFeed
            • markfree
              • Apr 2019
              • 875
              dade , are you following the official guide?
              Did you check the "database creation" contents?
              My suggestion is to start over following those docs and tweek DB only after a successful installation.
              • dade
                • Jan 2021
                • 34
                The problem was i trying to create DB on SD Card and it's a bad idea. I created a db on usb drive and worked. Ty all!
