Missing Graph
  • ZigbeeZabbix
    • Oct 2018
    Missing Graph
    Hello -
    Zabbix 5.2.4 / Centos8. I manually created a graph item within a template. The template was previously applied to approximately eight hosts. When browsing to Monitoring -> Hosts -> Click Hostname in Question -> Graphs, the Graph does not show on the page (only 20 other graphs). However, if I follow the same path but click on Configuration and then Graphs, the graph shows up in the list and can be previewed correctly. What I am I missing to get this graph on the main graph screen? Is it possible that there is pagination happening and the controls are just missing? I believe this has worked in previous releases, but not entirely sure.
    Thank you!
  • NilsA
    • Sep 2020
    • 102
    As far as I know, this has to do with a limit of graphs shown on the graphs section of a host. To put it simply, just add your graph to the template's screen or increase the limit of graphs shown on one page (I don't remember where the setting is - it might be in the php settings on your server).
    Putting the graph into the screen is the better option here since screens provide you with the means of sectioning different item graphs into groups of your own choosing.
