Reset monitoring hosts view reset?
  • roboris
    • Jan 2021
    • 16
    Somehow, my default view of hosts in the monitoring section includes a host group filter ("Teltonikas"). Every time I go to that view, it's filtered to only show Teltonikas. If I remove the host group from the filter and apply, I am shown all hosts... but if I push reset or reload the page, it automatically filters for Teltonikas again.
    How can I reset my default hosts view to show all hosts, without the Teltonikas filter?
  • roboris
    • Jan 2021
    • 16
    I have to believe that the action executed when I request "https://zabbix.server.net/zabbix.php?action=host.view" has somehow gotten the Teltonikas filter added its default presentation, but I don't know where to find the default setting to remove the Teltonikas filter. Any ideas, anyone? Can you please point me in the right direction?
    • markfree
      • Apr 2019
      • 875
      roboris Do you mean "Monitoring" > "Hosts"? Is the "Host Groups" box already filled with "Teltonikas" group?
      Did you check if you have a "favorite" filter selected?
      Have you tried to clear your browser's cache?
      • roboris
        • Jan 2021
        • 16
        markfree Yes, the Host Groups box contains "Teltonikas" every time I go to Monitoring > Hosts, and every time I reload the page in the browser. I have cleared my browser cache, no difference. Where would I select a favorite filter for the Home tab of Monitoring > Hosts?
        • markfree
          • Apr 2019
          • 875
          Are you seeing something like this?
          • roboris
            • Jan 2021
            • 16
            markfree I only have the Home tab, but it defaults to populating the host groups filter with Teltonikas. This is my issue.
Name:	Screen Shot 2021-02-05 at 12.33.39.png
            • markfree
              • Apr 2019
              • 875
              That's quite odd.
              Please, bare with me. Did you click at the small "X" next to Teltonikas group, then "apply"?
              Did you try to restart your server?
              • roboris
                • Jan 2021
                • 16
                Yes. Then it shows all hosts, like I want, but the next time I visit Monitoring > Hosts, or if I simply reload the page in my browser, Teltonikas is back in the host groups filter and only Teltonikas are shown.
                Yes, full shutdown and reboot, and restarted the zabbix-server service several times.
                • markfree
                  • Apr 2019
                  • 875
                  What browser are you using?
                  Have you tried switching to another browser?
                  • roboris
                    • Jan 2021
                    • 16
                    I’ve confirmed that the behavior is the same in different browsers, even browsers that haven’t visited our Zabbix instance before. It’s Zabbix doing this internally. Somehow, my default Monitoring > Hosts view includes the Teltonikas host groups filter, and I’m forced to remove it manually if I want to view all hosts.
                    • roboris
                      • Jan 2021
                      • 16
                      markfree Do you have any other thoughts on this?
                      • markfree
                        • Apr 2019
                        • 875
                        Sorry, roboris , I'm out of ideas.
                        I'm not sure the issue is with Zabbix server. It seems more like a PHP issue, but I am not good at that.
                        Someone more experienced could have some better opinion.
                        If it is not a hindrance to you, maybe you could reinstall your Zabbix or, at least, reinstall Zabbix Frontend.
                        apt-get install --reinstall zabbix-frontend-php
                        But make sure you backup everything before that!
                        • chamiltonj
                          • Apr 2021
                          I realize this is a very old thread, but I am having the same issue. I haven't solved it but I can confirm the issue has followed from 5.2 to 5.4.
