Netscreen syslog problem
  • bleedingpegasus
    • Sep 2006
    Hello all,
    I just installed this Zabbix, and already monitoring localhost with very little effort. But then I need to monitor netscreen syslog, which gives me problem.
    /etc/zabbix/zabbix_agentd.conf
    Hostname=localhost
    #DisableActive=1
    #EnableRemoteCommands=1
    ListenPort=10050
    Then in Menu->Configuration->Items:
    Description: Netscreen Syslog
    Type: ZABBIX agent(active)
    Key: log[/var/log/netscreen.log]
    Type of Information: log
    Update Interval: 3
    Keep in History: 90
    Keep trends: 365
    Status: Monitored
    Log time format: <empty>
    Applications: <none>
    - What should i expect to see?
    - In Monitoring->Latest Data, Last Check, Last value, and Change is empty (-) --> what went wrong?
    - In field log time format, should i enter something? if yes. what? can't find about it anywhere. (there are >2 other users asked this question without answer in this forum)
    Thanks in advance.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please check http://www.zabbix.com/manual/v1.1/tu...s_logfiles.php
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bleedingpegasus
      • Sep 2006
      More interesting
      Yes... i got it working now.
      But all i can see if very raw data.
      Is it possible to let zabbix parse the log entry?
      One of the entry is looking like this:
      Not classified Sep 11 15:56:22 10.0.x.x ns50: NetScreen device_id=xxXX [No Name]system-notification-00257(traffic): start_time="2006-xx-xx xx:xx:xx" duration=3 policy_id=x service=http proto=x src zone=Trust dst zone=Untrust action=Permit sent=7097 rcvd=1466 src=10.0.x.x dst=x.y.z.w src_port=xxxx dst_port=80 src-xlated ip=a.b.c.d port=12110 session_id=63575
      So, how do i parse the information, so zabbix can display graph, let say, per ip, or per hour statistic?
      Anybody has similar experience
      • bleedingpegasus
        • Sep 2006
        I believe this kind of parsing (if there's no plug-ins at all) has to be done manually. I won't mind at all to do some perl/php scripting.
        So, if anybody can tell me which file(s) do i have to start? and which tables should i mess up, or any clue at all, these would make my life easier.
        nb. the info from netscreen must be in syslog format, not snmp.
