Unknown metrics docker.XXXXX using zabbix agent2 using official template
  • Gabbs
    • Feb 2020
    • 11
    I am running zabbix agent2 (v1:5.0.6-2+bionic ) on Ubuntu 18.04 in active mode to monitor docker containers on my host. Docker is running on docker-ce 5:19.03.0
    I have added zabbix user to the docker group.
    # getent group docker | grep -o zabbix
    zabbix
    I have created the host and among other templates I added the official template called "Template App Docker Active Agent" "Template tooling version used: 0.35".
    What seems to be working okay is:
    Containers discovery
    Images discovery
    Many non-discovered items however are marked "unknown". Enabled and increased log level to maximum level "trace" in agent2 which shows these errors.
    2021/02/05 14:06:43.837686 [101] cannot monitor metric "docker.architecture": Unknown metric docker.architecture
    2021/02/05 14:06:43.837693 [101] cannot monitor metric "docker.cgroup_driver": Unknown metric docker.cgroup_driver
    2021/02/05 14:06:43.837697 [101] adding new request for key: 'docker.containers'
    2021/02/05 14:06:43.837707 [101] cannot monitor metric "docker.containers.paused": Unknown metric docker.containers.paused
    2021/02/05 14:06:43.837718 [101] cannot monitor metric "docker.containers.running": Unknown metric docker.containers.running
    2021/02/05 14:06:43.837724 [101] cannot monitor metric "docker.containers.stopped": Unknown metric docker.containers.stopped
    2021/02/05 14:06:43.837730 [101] cannot monitor metric "docker.containers.total": Unknown metric docker.containers.total
    2021/02/05 14:06:43.837736 [101] cannot monitor metric "docker.containers_size": Unknown metric docker.containers_size
    2021/02/05 14:06:43.837744 [101] cannot monitor metric "docker.cpu_cfs_period.enabled": Unknown metric docker.cpu_cfs_period.enabled
    2021/02/05 14:06:43.837760 [101] cannot monitor metric "docker.cpu_cfs_quota.enabled": Unknown metric docker.cpu_cfs_quota.enabled
    2021/02/05 14:06:43.837777 [101] cannot monitor metric "docker.cpu_set.enabled": Unknown metric docker.cpu_set.enabled
    2021/02/05 14:06:43.837782 [101] cannot monitor metric "docker.cpu_shares.enabled": Unknown metric docker.cpu_shares.enabled
    2021/02/05 14:06:43.837788 [101] adding new request for key: 'docker.data_usage'
    2021/02/05 14:06:43.837806 [101] cannot monitor metric "docker.debug.enabled": Unknown metric docker.debug.enabled
    2021/02/05 14:06:43.837813 [101] cannot monitor metric "docker.default_runtime": Unknown metric docker.default_runtime
    2021/02/05 14:06:43.837819 [101] cannot monitor metric "docker.driver": Unknown metric docker.driver
    2021/02/05 14:06:43.837825 [101] cannot monitor metric "docker.goroutines": Unknown metric docker.goroutines
    2021/02/05 14:06:43.837831 [101] adding new request for key: 'docker.images'
    2021/02/05 14:06:43.837840 [101] cannot monitor metric "docker.images.top_level": Unknown metric docker.images.top_level
    2021/02/05 14:06:43.837848 [101] cannot monitor metric "docker.images.total": Unknown metric docker.images.total
    2021/02/05 14:06:43.837852 [101] cannot monitor metric "docker.images_size": Unknown metric docker.images_size
    2021/02/05 14:06:43.837866 [101] adding new request for key: 'docker.info'
    2021/02/05 14:06:43.837883 [101] cannot monitor metric "docker.ipv4_forwarding.enabled": Unknown metric docker.ipv4_forwarding.enabled
    2021/02/05 14:06:43.837891 [101] cannot monitor metric "docker.kernel_mem.enabled": Unknown metric docker.kernel_mem.enabled
    2021/02/05 14:06:43.837897 [101] cannot monitor metric "docker.kernel_mem_tcp.enabled": Unknown metric docker.kernel_mem_tcp.enabled
    2021/02/05 14:06:43.837905 [101] cannot monitor metric "docker.kernel_version": Unknown metric docker.kernel_version
    2021/02/05 14:06:43.837911 [101] cannot monitor metric "docker.layers_size": Unknown metric docker.layers_size
    2021/02/05 14:06:43.837925 [101] cannot monitor metric "docker.live_restore.enabled": Unknown metric docker.live_restore.enabled
    2021/02/05 14:06:43.837932 [101] cannot monitor metric "docker.logging_driver": Unknown metric docker.logging_driver
    2021/02/05 14:06:43.837946 [101] cannot monitor metric "docker.mem.total": Unknown metric docker.mem.total
    2021/02/05 14:06:43.837952 [101] cannot monitor metric "docker.mem_limit.enabled": Unknown metric docker.mem_limit.enabled
    2021/02/05 14:06:43.837959 [101] cannot monitor metric "docker.name": Unknown metric docker.name
    2021/02/05 14:06:43.837968 [101] cannot monitor metric "docker.ncpu": Unknown metric docker.ncpu
    2021/02/05 14:06:43.837980 [101] cannot monitor metric "docker.nevents_listener": Unknown metric docker.nevents_listener
    2021/02/05 14:06:43.837987 [101] cannot monitor metric "docker.nfd": Unknown metric docker.nfd
    2021/02/05 14:06:43.837998 [101] cannot monitor metric "docker.oomkill.disabled": Unknown metric docker.oomkill.disabled
    2021/02/05 14:06:43.838005 [101] cannot monitor metric "docker.operating_system": Unknown metric docker.operating_system
    2021/02/05 14:06:43.838017 [101] cannot monitor metric "docker.os_type": Unknown metric docker.os_type
    2021/02/05 14:06:43.838023 [101] cannot monitor metric "docker.pids_limit.enabled": Unknown metric docker.pids_limit.enabled
    Can someone please help with the above? Is this supposed to work or not? Is this a bug? Am I missing a configuration on the agent side that prevents the agent2 to read more docker stats?
    Thank you!
Name:	Screenshot 2021-02-05 at 12.58.33.png
  • Gabbs
    • Feb 2020
    • 11
    Wish I resolved everything so quickly Not sure why but those items marked unknown should be Dependent items not Zabbix Agent (Active). Don't know why they changed but hey ho. Updated template and it kicked into life
