Host not registering on Proxy 5.2
  • Shurman
    • Mar 2014
    • 44
    Hi everyone!
    I am trying to implement a proxy configuration. Host configuration data is sent to the proxy from server, however for some reason it is not inthe database...
    291954:20210209:125215.210 In process_proxyconfig_table() table:'hosts'
    291954:20210209:125215.210 query [txnlev:1] [select hostid,host,status,available,ipmi_authtype,ipmi_pr ivilege,ipmi_username,ipmi_password,ipmi_available ,snmp_available,jmx_available,name,t
    ls_connect,tls_accept,tls_issuer,tls_subject,tls_p sk_identity,tls_psk from hosts]
    291954:20210209:125215.212 query [txnlev:1] [insert into hosts (hostid,host,status,available,ipmi_authtype,ipmi_p rivilege,ipmi_username,ipmi_password,ipmi_availabl e,snmp_available,jmx_avai
    lable,name,tls_connect,tls_accept,tls_issuer,tls_s ubject,tls_psk_identity,tls_psk,description) values (10001,'Template OS Linux',3,0,-1,2,'','',0,0,0,'Template OS Linux',1,1,'','','','',''
    ),(10050,'Template App Zabbix Agent',3,0,-1,2,'','',0,0,0,'Template App Zabbix Agent',1,1,'','','','',''),(10332,'IVR', 0,0,-1,2,'','',0,0,0,'IVR',1,1,'','','','','' ),(1
    0333,'Asterisk',3,0,-1,2,'','',0,0,0,'Asterisk',1,1,'','','','',''),(10 336,'Zabbix',0,0,-1,2,'','',0,0,0,'Zabbix',1,1,'','','','' ,'');
    291954:20210209:125215.213 End of process_proxyconfig_table():SUCCEED
    So it looks like it should be in the DB.
    But it is not:
    MariaDB [zabbix_proxy]> select * from hosts;
    Empty set (0.000 sec)
    MariaDB [zabbix_proxy]> select * from autoreg_host;
    and then in proxy log I get
    291958:20210209:131304.682 zbx_setproctitle() title:'trapper #5 [processing data]'
    291958:20210209:131304.683 trapper got '{"request":"active checks","host":"IVR"}'
    291958:20210209:131304.683 In send_list_of_active_checks_json()
    291958:20210209:131304.683 In is_ip4() ip:'192.168.22.116'
    291958:20210209:131304.683 End of is_ip4():SUCCEED
    291958:20210209:131304.683 In get_hostid_by_host() host:'IVR' metadata:''
    291958:20210209:131304.683 query [txnlev:0] [select h.hostid,h.status,h.tls_accept,h.tls_issuer,h.tls_ subject,h.tls_psk_identity,a.host_metadata,a.liste n_ip,a.listen_dns,a.listen_port,a.flags from hosts h left join autoreg_host a on a.proxy_hostid is null and a.host=h.host where h.host='IVR' and h.status in (0,1) and h.flags<>2 and h.proxy_hostid is null]
    291958:20210209:131304.752 query [txnlev:1] [begin;]
    291958:20210209:131304.752 query [txnlev:1] [insert into proxy_autoreg_host (clock,host,listen_ip,listen_dns,listen_port,tls_a ccepted,host_metadata,flags) values (1612858384,'IVR','192.168.22.116','',10 050,1,'',0)]
    291958:20210209:131304.753 query [txnlev:1] [commit;]
    291958:20210209:131304.757 End of get_hostid_by_host():FAIL
    291958:20210209:131304.757 cannot send list of active checks to "192.168.22.116": host [IVR] not found
    zabbix-proxy-mysql-5.2.4-1.el8.x86_64 from official repo
  • Shurman
    • Mar 2014
    • 44
    Could it be because there is no commit after insert?
    Insert into proxy_autoreg_host is ok:
    293480:20210209:135806.672 query [txnlev:1] [begin;]
    293480:20210209:135806.672 query [txnlev:1] [insert into proxy_autoreg_host (clock,host,listen_ip,listen_dns,listen_port,tls_a ccepted,host_metadata,flags) values (1612861086,'IVR
    ','192.168.22.116','',10050,1,'',0)]
    293480:20210209:135806.672 query [txnlev:1] [commit;]
    also, it seems the table keeps filling with duplicate records.... is it supposed to be like this?
    MariaDB [zabbix_proxy]> select * from proxy_autoreg_host;
    | id | clock | host | listen_ip | listen_port | listen_dns | host_metadata | flags | tls_accepted |
    | 1 | 1612860486 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 2 | 1612860534 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 3 | 1612860606 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 4 | 1612860654 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 5 | 1612860726 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 6 | 1612860774 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 7 | 1612860846 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 8 | 1612860894 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 9 | 1612860966 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 10 | 1612861014 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 11 | 1612861086 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 12 | 1612861134 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    | 13 | 1612861206 | IVR | 192.168.22.116 | 10050 | | | 0 | 1 |
    | 14 | 1612861254 | Zabbix | 192.168.22.1 | 10050 | flashfon1 | | 0 | 1 |
    14 rows in set (0.000 sec)
    • Hamardaban
      • May 2019
      • 2713
      Perhaps your problem is simpler and does not require a proxy database investigation
      Check the «Hostname» match in the agent configuration and in the «hostnames» settings of the corresponding host.
      https://www.zabbix.com/documentation.../zabbix_agentd
      Required for active checks and must match hostnames as configured on the server.
      • Shurman
        • Mar 2014
        • 44
        Of course the host name is the first thing to check, I know they must be identical (using Zabbix since 2008 ;-) ).
        But please note (keeping that the log is from Proxy):
        - the first piece of log is when Server send config to Proxy, with 2 hosts that are configured to be monitored through proxy;
        - the second piece of log is when the Agent requests list of active checks from Proxy.
        In both cases the host name is the same.
