Problem installing Zabbix using Postgresql
  • ktenney
    • Mar 2015
    Howdy,
    Ubuntu 14.04
    Installed zabbix-server-pgsql, zabbix-frontend-php from repo.zabbix.com
    At #3, 'Configure DB connection', only choice is 'MySQL'
    What am I missing?
    Thanks,
    Kent
  • Atsushi
    • Aug 2013
    • 2028
    Please try install php5-pgsql package.
    • ktenney
      • Mar 2015
      Thank you, now the postgresql option is seen
      next, get the db created and configured correctly ...
      • Hal0n
        • Feb 2016
        3.0.0 PostgreSQL installation is just plain broken
        The manual points to three .sql schema files that just plain don't exist. Found the forum post that points out that you can:
        cd /usr/share/doc/zabbix-server-pgsql
        gunzip create.sql.gz
        psql -U zabbix -h localhost zabbix < create.sql
        I was thrilled to see that my http://<fqdn-hostname>/zabbix page was now available. I fixed the Timezone setting, and found myself with only a choice of MySQL.
        Ok, so now I find myself on this thread, and I install the 'php5-pgsql' package. Great! Now I have PostgreSQL as an option. Except now I have:
        Cannot connect to the database.
        Details
        The frontend does not match Zabbix database.
        I have not ever even downloaded any version of Zabbix besides 3.0.0. There is no possible way that this is an artifact of a botched upgrade because it is a 100% clean install.
        • Stefan_D
          • Sep 2015
          • 18
          Details
          which distribution do you use? One of my test machines for example is a SLES12 box. The necessary .sql files are located at:
          /usr/share/doc/packages/zabbix30-server/postgresql/
          maybe you have to use find on your /usr directory.
          Cheers,
          SD
          • Hal0n
            • Feb 2016
            Missing SQL Import Statements for Debian + PostgreSQL on 3.0.0
            Actually I did a find for all .sql files before.
            root@zabbix-test:/usr/share/doc# find / -name *.sql*
            /usr/share/postgresql/9.5/system_views.sql
            /usr/share/postgresql/9.5/extension/intagg--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/dict_int--1.0.sql
            /usr/share/postgresql/9.5/extension/btree_gist--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/dblink--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/lo--1.0.sql
            /usr/share/postgresql/9.5/extension/autoinc--1.0.sql
            /usr/share/postgresql/9.5/extension/citext--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_freespacemap--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_buffercache--1.1.sql
            /usr/share/postgresql/9.5/extension/fuzzystrmatch--1.0.sql
            /usr/share/postgresql/9.5/extension/dblink--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_trgm--1.1.sql
            /usr/share/postgresql/9.5/extension/pageinspect--1.3.sql
            /usr/share/postgresql/9.5/extension/pg_stat_statements--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_prewarm--1.0.sql
            /usr/share/postgresql/9.5/extension/pageinspect--1.2--1.3.sql
            /usr/share/postgresql/9.5/extension/dblink--1.1.sql
            /usr/share/postgresql/9.5/extension/pg_stat_statements--1.2--1.3.sql
            /usr/share/postgresql/9.5/extension/sslinfo--1.0.sql
            /usr/share/postgresql/9.5/extension/intarray--1.0.sql
            /usr/share/postgresql/9.5/extension/hstore--1.2--1.3.sql
            /usr/share/postgresql/9.5/extension/xml2--1.0.sql
            /usr/share/postgresql/9.5/extension/pageinspect--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/pgrowlocks--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/cube--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/tsm_system_time--1.0.sql
            /usr/share/postgresql/9.5/extension/pgcrypto--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgrowlocks--1.1.sql
            /usr/share/postgresql/9.5/extension/unaccent--1.0.sql
            /usr/share/postgresql/9.5/extension/ltree--1.0.sql
            /usr/share/postgresql/9.5/extension/pgstattuple--1.2--1.3.sql
            /usr/share/postgresql/9.5/extension/hstore--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/file_fdw--1.0.sql
            /usr/share/postgresql/9.5/extension/pageinspect--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/chkpass--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/earthdistance--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_trgm--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/postgres_fdw--1.0.sql
            /usr/share/postgresql/9.5/extension/isn--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/moddatetime--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/dict_xsyn--1.0.sql
            /usr/share/postgresql/9.5/extension/refint--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/intarray--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/tsearch2--1.0.sql
            /usr/share/postgresql/9.5/extension/pgstattuple--1.3.sql
            /usr/share/postgresql/9.5/extension/insert_username--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgcrypto--1.2.sql
            /usr/share/postgresql/9.5/extension/pg_stat_statements--1.1--1.2.sql
            /usr/share/postgresql/9.5/extension/pgstattuple--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/autoinc--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/adminpack--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_buffercache--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/timetravel--1.0.sql
            /usr/share/postgresql/9.5/extension/uuid-ossp--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/hstore--1.1--1.2.sql
            /usr/share/postgresql/9.5/extension/pg_trgm--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgcrypto--1.1--1.2.sql
            /usr/share/postgresql/9.5/extension/citext--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/seg--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/chkpass--1.0.sql
            /usr/share/postgresql/9.5/extension/hstore--1.3.sql
            /usr/share/postgresql/9.5/extension/insert_username--1.0.sql
            /usr/share/postgresql/9.5/extension/plpgsql--1.0.sql
            /usr/share/postgresql/9.5/extension/tablefunc--1.0.sql
            /usr/share/postgresql/9.5/extension/moddatetime--1.0.sql
            /usr/share/postgresql/9.5/extension/cube--1.0.sql
            /usr/share/postgresql/9.5/extension/timetravel--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgstattuple--1.1--1.2.sql
            /usr/share/postgresql/9.5/extension/pg_buffercache--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/btree_gin--1.0.sql
            /usr/share/postgresql/9.5/extension/pgstattuple--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_stat_statements--1.3.sql
            /usr/share/postgresql/9.5/extension/unaccent--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/sslinfo--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/seg--1.0.sql
            /usr/share/postgresql/9.5/extension/ltree--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgcrypto--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/xml2--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/intagg--1.0.sql
            /usr/share/postgresql/9.5/extension/tablefunc--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/dict_xsyn--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/lo--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/plpgsql--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/uuid-ossp--1.0.sql
            /usr/share/postgresql/9.5/extension/fuzzystrmatch--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pgrowlocks--1.0--1.1.sql
            /usr/share/postgresql/9.5/extension/hstore--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/btree_gist--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/btree_gin--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/dict_int--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/tsm_system_rows--1.0.sql
            /usr/share/postgresql/9.5/extension/isn--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_freespacemap--1.0.sql
            /usr/share/postgresql/9.5/extension/tcn--1.0.sql
            /usr/share/postgresql/9.5/extension/btree_gist--1.1.sql
            /usr/share/postgresql/9.5/extension/citext--1.1.sql
            /usr/share/postgresql/9.5/extension/pageinspect--1.1--1.2.sql
            /usr/share/postgresql/9.5/extension/refint--1.0.sql
            /usr/share/postgresql/9.5/extension/tsearch2--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/earthdistance--unpackaged--1.0.sql
            /usr/share/postgresql/9.5/extension/pg_stat_statements--1.0--1.1.sql
            /usr/share/postgresql/9.5/conversion_create.sql
            /usr/share/postgresql/9.5/information_schema.sql
            /usr/share/postgresql/9.5/snowball_create.sql
            /usr/share/postgresql/9.4/system_views.sql
            /usr/share/postgresql/9.4/extension/pgstattuple--1.2.sql
            /usr/share/postgresql/9.4/extension/intagg--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/dict_int--1.0.sql
            /usr/share/postgresql/9.4/extension/dblink--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/lo--1.0.sql
            /usr/share/postgresql/9.4/extension/autoinc--1.0.sql
            /usr/share/postgresql/9.4/extension/citext--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_freespacemap--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/fuzzystrmatch--1.0.sql
            /usr/share/postgresql/9.4/extension/dblink--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_trgm--1.1.sql
            /usr/share/postgresql/9.4/extension/pg_stat_statements--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_prewarm--1.0.sql
            /usr/share/postgresql/9.4/extension/btree_gist--1.0.sql
            /usr/share/postgresql/9.4/extension/dblink--1.1.sql
            /usr/share/postgresql/9.4/extension/sslinfo--1.0.sql
            /usr/share/postgresql/9.4/extension/intarray--1.0.sql
            /usr/share/postgresql/9.4/extension/hstore--1.2--1.3.sql
            /usr/share/postgresql/9.4/extension/xml2--1.0.sql
            /usr/share/postgresql/9.4/extension/pageinspect--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/pgrowlocks--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/cube--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pgcrypto--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pgrowlocks--1.1.sql
            /usr/share/postgresql/9.4/extension/unaccent--1.0.sql
            /usr/share/postgresql/9.4/extension/ltree--1.0.sql
            /usr/share/postgresql/9.4/extension/worker_spi--1.0.sql
            /usr/share/postgresql/9.4/extension/hstore--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/file_fdw--1.0.sql
            /usr/share/postgresql/9.4/extension/pageinspect--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_buffercache--1.0.sql
            /usr/share/postgresql/9.4/extension/chkpass--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/earthdistance--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_trgm--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/postgres_fdw--1.0.sql
            /usr/share/postgresql/9.4/extension/isn--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/moddatetime--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/dict_xsyn--1.0.sql
            /usr/share/postgresql/9.4/extension/refint--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/intarray--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/tsearch2--1.0.sql
            /usr/share/postgresql/9.4/extension/pgcrypto--1.1.sql
            /usr/share/postgresql/9.4/extension/insert_username--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_stat_statements--1.1--1.2.sql
            /usr/share/postgresql/9.4/extension/pgstattuple--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/autoinc--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/adminpack--1.0.sql
            /usr/share/postgresql/9.4/extension/timetravel--1.0.sql
            /usr/share/postgresql/9.4/extension/uuid-ossp--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/hstore--1.1--1.2.sql
            /usr/share/postgresql/9.4/extension/pg_trgm--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/citext--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/seg--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/chkpass--1.0.sql
            /usr/share/postgresql/9.4/extension/hstore--1.3.sql
            /usr/share/postgresql/9.4/extension/insert_username--1.0.sql
            /usr/share/postgresql/9.4/extension/plpgsql--1.0.sql
            /usr/share/postgresql/9.4/extension/tablefunc--1.0.sql
            /usr/share/postgresql/9.4/extension/moddatetime--1.0.sql
            /usr/share/postgresql/9.4/extension/cube--1.0.sql
            /usr/share/postgresql/9.4/extension/timetravel--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pageinspect--1.2.sql
            /usr/share/postgresql/9.4/extension/pgstattuple--1.1--1.2.sql
            /usr/share/postgresql/9.4/extension/pg_stat_statements--1.2.sql
            /usr/share/postgresql/9.4/extension/pg_buffercache--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/btree_gin--1.0.sql
            /usr/share/postgresql/9.4/extension/pgstattuple--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/unaccent--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/sslinfo--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/seg--1.0.sql
            /usr/share/postgresql/9.4/extension/ltree--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pgcrypto--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/xml2--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/intagg--1.0.sql
            /usr/share/postgresql/9.4/extension/tablefunc--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/citext--1.1--1.0.sql
            /usr/share/postgresql/9.4/extension/dict_xsyn--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/lo--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/plpgsql--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/uuid-ossp--1.0.sql
            /usr/share/postgresql/9.4/extension/fuzzystrmatch--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pgrowlocks--1.0--1.1.sql
            /usr/share/postgresql/9.4/extension/hstore--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/btree_gist--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/btree_gin--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/dict_int--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/citext--1.0.sql
            /usr/share/postgresql/9.4/extension/isn--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_freespacemap--1.0.sql
            /usr/share/postgresql/9.4/extension/test_shm_mq--1.0.sql
            /usr/share/postgresql/9.4/extension/tcn--1.0.sql
            /usr/share/postgresql/9.4/extension/citext--1.1.sql
            /usr/share/postgresql/9.4/extension/pageinspect--1.1--1.2.sql
            /usr/share/postgresql/9.4/extension/refint--1.0.sql
            /usr/share/postgresql/9.4/extension/tsearch2--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/earthdistance--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/test_parser--1.0.sql
            /usr/share/postgresql/9.4/extension/test_parser--unpackaged--1.0.sql
            /usr/share/postgresql/9.4/extension/pg_stat_statements--1.0--1.1.sql
            /usr/share/postgresql/9.4/conversion_create.sql
            /usr/share/postgresql/9.4/information_schema.sql
            /usr/share/postgresql/9.4/snowball_create.sql
            /usr/share/doc/zabbix-server-pgsql/create.sql
            I carefully documented my install so far:
            sudo su -
            wget http://repo.zabbix.com/zabbix/3.0/de...wheezy_all.deb
            dpkg -i zabbix-release_3.0-1+wheezy_all.deb
            apt-get update
            apt-get install zabbix-server-pgsql
            apt-get install zabbix-frontend-php
            apt-get install zabbix-agent
            apt-get install php5-pgsql
            cd /etc/apt/sources.list.d
            vi pgdg.list
            ### paste the following line into pgdg.list and then write quit ###
            deb http://apt.postgresql.org/pub/repos/apt/ wheezy-pgdg main
            ### end of vi session (:wq) ###
            vi ACCC4CF8.asc
            ### paste contents of clipboard (:wq) ###
            apt-key add /root/ACCC4CF8.asc
            apt-get update
            apt-get install postgresql-client-9.4
            apt-get install postgresql-9.4
            su - postgres
            psql
            CREATE USER zabbix PASSWORD '<password>';
            CREATE SCHEMA zabbix;
            GRANT ALL ON ALL TABLES IN SCHEMA zabbix TO zabbix;
            ALTER USER zabbix CREATEDB;
            CREATE DATABASE zabbix;
            \q
            • Hal0n
              • Feb 2016
              Solution my manager came up with for Debian + Postgres on 3.0.1
              Made sure only Postgres 9.5 was installed. (.4 was still installed, hadn't been replaced.
              user@zabbix-test:~$ sudo -u postgres psql
              psql (9.5.1)
              Type "help" for help.
              postgres=# create role zabbix;
              CREATE ROLE
              postgres=# alter role zabbix with password 'xxxxx';
              ALTER ROLE
              postgres=# alter role zabbix with superuser;
              ALTER ROLE
              postgres=# alter role zabbix with CREATEDB;
              ALTER ROLE
              postgres=# alter role zabbix with CREATEROLE;
              ALTER ROLE
              postgres=# create database zabbix with owner zabbix;
              CREATE DATABASE
              user@zabbix-test:~$ wget http://downloads.sourceforge.net/pro...se_mirror=iweb
              user@zabbix-test:~$ tar -xzf zabbix-3.0.1.tar.gz
              user@zabbix-test:~$ cd zabbix-3.0.1
              user@zabbix-test:~/zabbix-3.0.1$ cd database/postgresql
              user@zabbix-test:~/zabbix-3.0.1/database/postgresql$ ls -l
              total 2920
              -rw-r--r-- 1 user users 893005 Feb 26 03:46 data.sql
              -rw-r--r-- 1 user users 1979089 Feb 26 03:45 images.sql
              -rw-r--r-- 1 user users 109366 Feb 26 03:46 schema.sql
              user@zabbix-test:~/zabbix-3.0.1/database/postgresql$ sudo -u postgres psql zabbix < schema.sql
              user@zabbix-test:~/zabbix-3.0.1/database/postgresql$ sudo -u postgres psql zabbix < images.sql
              user@zabbix-test:~/zabbix-3.0.1/database/postgresql$ sudo -u postgres psql zabbix < data.sql
              • pester
                • Mar 2016
                Same problem here but turns out user zabbix wasn't permitted to login.
                Found this in /var/log/postgresql/postgresql-9.4-main.log
                2016-03-21 15:51:27 CDT [12582-1] zabbix@zabbix FATAL: role "zabbix" is not permitted to log in
                Fix was simple:
                postgres=# CREATE ROLE zabbix WITH LOGIN;
                ERROR: role "zabbix" already exists
                postgres=# ALTER ROLE zabbix LOGIN;
                ALTER ROLE
                postgres=#
                • Karl_MCS
                  • Dec 2015
                  For Ubuntu Bionic and Zabbix 3.4, this package is php-pgsql. Needs to be added to official documentation.
                  • dimir
                    Zabbix developer
                    • Apr 2011
                    • 1080
                    php-pgsql is automatically installed with zabbix-frontend-php as of version 3.2.3
