Network Graph Isn't Tracking
  • Brave
    • Feb 2021
    I ran https://github.com/masonr/yet-another-bench-script and https://github.com/sivel/speedtest-cli/ and Zabbix didn't track the correct speeds nor is it tracking the network speeds when I run the the speedtest script. Disk read/write rates also isn't tracking. I've also noticed that the stacked shows the actual speeds on the graph it self but the data information on the bottom doesn't reflect the graph or the non stacked graph. In the stacked graph, the first spike didn't reflect the last, min, avg & max data, on the second spike the data started to reflect but for the non stacked graph the data doesn't match the other graph or the speeds and tests that were done. I did the speedtest script at 10:20 and did a second at 10:22 and the speeds were never tracked
    root@cloud:~# curl -sL yabs.sh | bash
    # Yet-Another-Bench-Script #
    # v2020-12-29 #
    # https://github.com/masonr/yet-another-bench-script #
    Tue Feb 16 09:48:55 PM EST 2021
    Basic System Information:
    Processor : Intel Core Processor (Broadwell, no TSX, IBRS)
    CPU cores : 1 @ 2394.454 MHz
    AES-NI : ✔ Enabled
    VM-x/AMD-V : ❌ Disabled
    RAM : 977.5 MiB
    Swap : 1024.0 MiB
    Disk : 23.4 GiB
    fio Disk Speed Tests (Mixed R/W 50/50):
    Block Size | 4k (IOPS) | 64k (IOPS)
    Read | 87.78 MB/s (21.9k) | 155.36 MB/s (2.4k)
    Write | 88.02 MB/s (22.0k) | 156.18 MB/s (2.4k)
    Total | 175.80 MB/s (43.9k) | 311.54 MB/s (4.8k)
    Block Size | 512k (IOPS) | 1m (IOPS)
    Read | 172.78 MB/s (337) | 160.84 MB/s (157)
    Write | 181.96 MB/s (355) | 171.55 MB/s (167)
    Total | 354.75 MB/s (692) | 332.40 MB/s (324)
    iperf3 Network Speed Tests (IPv4):
    Provider | Location (Link) | Send Speed | Recv Speed
    Clouvider | London, UK (10G) | busy | busy
    Online.net | Paris, FR (10G) | 2.01 Gbits/sec | 1.79 Gbits/sec
    WorldStream | The Netherlands (10G) | 1.69 Gbits/sec | busy
    Biznet | Jakarta, Indonesia (1G) | busy | 7.03 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 3.52 Gbits/sec | 2.35 Gbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 5.80 Gbits/sec | 4.88 Gbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 2.85 Gbits/sec | 1.58 Gbits/sec
    Iveloz Telecom | Sao Paulo, BR (2G) | 1.31 Gbits/sec | 1.66 Gbits/sec
    iperf3 Network Speed Tests (IPv6):
    Online.net | Paris, FR (10G) | 1.88 Gbits/sec | 1.65 Gbits/sec
    WorldStream | The Netherlands (10G) | 1.69 Gbits/sec | 827 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 7.15 Gbits/sec | 2.67 Gbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 2.84 Gbits/sec | 1.57 Gbits/sec
    Geekbench 5 Benchmark Test:
    Test | Value
    Single Core | 620
    Multi Core | 611
    Full Test | https://browser.geekbench.com/v5/cpu/6543637
    root@cloud:~# speedtest-cli
    Retrieving speedtest.net configuration...
    Testing from Choopa, LLC (45.77.160.251)...
    Retrieving speedtest.net server list...
    Selecting best server based on ping...
    Hosted by Grupo GTD (Miami, FL) [2.79 km]: 1.104 ms
    Testing download speed............................................. ...................................
    Download: 3049.19 Mbit/s
    Testing upload speed............................................. .................................................. .......
    Upload: 2270.16 Mbit/s
    root@cloud:~#
ID:	418929Click image for larger version
