response code "301" did not match any of the required status codes "200"
  • mixmox
    • Apr 2020
    • 54
    Hello
    im working on Web scenarios to monitor my webserver from any error like 503 504 404 and ... .
    if it detect any error type, send warning.
    so use Web scenarios with this configuration:
    add senario with name of "Availability" and set "Firefox" az agent, then add one step to check url with this pattern: httpS://domain.com/
    and set Required status codes to 200.
    but in last data ive get this error:
    ive try to add another step to confirm 301 but nothing changed
    any idea?
    • 4996
    Required status codes List of expected HTTP status codes. If Zabbix gets a code which is not in the list, the step will fail.
    If empty, no check on status codes is performed.
    For example: 200,201,210-299
    User macros are supported since Zabbix 2.2.
    https://www.zabbix.com/documentation...web_monitoring
    Maybe you should also tick that "Follow redirects" checkbox. Then it shoudl follow your permanent redirect and end up in that real page you are looking for.
