Trying to get timestamps in json call in php
  • waardd
    • Aug 2014
    • 82
    Im trying to parse a variable into a json call but the values are not transfered... can anybody point me in the right direction?
    date_default_timezone_set("Europe/Amsterdam");
    echo "Europe/Amsterdam:".time();
    $fromtime = time();
    echo "<br>";
    echo "From time: ". $fromtime;
    echo "<br>";
    $totime= time() - (7 * 24 * 60 * 60 );
    echo "To time: ". $totime;
    echo "<br>";
    function zabbix_get_events($uri, $authtoken) {
    "params": {
        "time_from": "1284910040",
        "time_till": "1284991200",
        "output": "extend",
        "sortfield": "clock",
        "sortorder": "desc",
        "limit": 10
            $data = array(
                    'jsonrpc' => "2.0",
                    'method' => "event.get",
                    'params' => array(
                            'time_from' => "".$fromtime,
                            'time_till' => "".$totime,
                            'output' => "extend",
                            'sortfield' => "clock",
                            'sortorder' => "desc",
                            'limit'=> 10
                    'id' => "2",
                    'auth' => $authtoken
            $response = json_request($uri, $data);
            return $response['result'];
    translates to:
    JSON Request:
    {"jsonrpc":"2.0","method":"event.get","params":{"time_from":"","time_till":"","output":"extend","sortfield":"clock","sortorder":"desc","limit":10},"id":"2","auth":"8be687b6aff4f99e14c906dbe01755b4"}
  • zabbixx
    • Jul 2012
    • 71
    Hello, what is the name of this variable that you cant pas to the data ?
    maybe you try to putput this var in the php... is it existing is it empty ?
    use global to acces variables that are global defined (not in the function)
    <?php
    $a = 1;
    $b = 2;
    function Summe()
        global $a, $b;
        $b = $a + $b;
    Summe();
    echo $b;
    • waardd
      • Aug 2014
      • 82
      I figured it out... i should parse it in the function call
      Tnx
