HP MSA 2040 error
  • sphtd7
    • Dec 2020
    • 52
    HP MSA 2040 error
    Hi!
    I want to add HP MSA 2040 to zabbix. https://github.com/asand3r/zbx-hpmsa...storage-models
    Unfortunately, I have a problem. If I choose a template without ssl I have the following result:
    Traceback (most recent call last):
    File "/usr/share/zabbix/externalscripts/zbx-hpmsa.py", line 673, in <module>
    skey = get_skey(MSA_CONNECT, CRED_HASH)
    File "/usr/share/zabbix/externalscripts/zbx-hpmsa.py", line 169, in get_skey
    return get_skey(msa, hashed_login, use_cache=False)
    File "/usr/share/zabbix/externalscripts/zbx-hpmsa.py", line 174, in get_skey
    ret_code, sessionkey, xml = query_xmlapi(url=url, sessionkey=None)
    File "/usr/share/zabbix/externalscripts/zbx-hpmsa.py", line 259, in query_xmlapi
    response_xml = eTree.fromstring(response.content)
    File "/usr/lib/python3.8/xml/etree/ElementTree.py", line 1320, in XML
    parser.feed(text)
    xml.etree.ElementTree.ParseError: syntax error: line 1, column 49
    If the template with SSL, the result is:
    ERROR: Cannot verify storage SSL Certificate.
    As for the certificate, I understand that I should simply download it from my storage?
  • sphtd7
    • Dec 2020
    • 52
    Hi, i need still your help.
    • Richard_69
      • Oct 2020
      HP MSA 2040 storage scales up to 199 SFF disk drives and delivers the data Technical Specialist owns call end-to-end until the problem is resolved to the.
      www.nomnomnow.one
      • sphtd7
        • Dec 2020
        • 52
        No one? Refresh
