Failure to import initial schema and data
  • VV666
    • Mar 2021
    Hello, I'm following this documentation : https://www.zabbix.com/download?zabb...uster&db=mysql
    I'm blocking at step C : "On Zabbix server host initial import schema and data. You will be prompted to enter your newly created password."
    $ zcat /usr/share/doc/zabbix-server-mysql/create.sql.gz | mysql -uzabbix2 -p zabbix
    Enter password:
    ERROR 1071 (42000) at line 357: Specified key was too long; max key length is 1000 bytes
    All I find as a solution on the Internet is to change the snack to ut8_bin, but it's already the case.
    Why do I have this error?
    I'm running Debian 10 and MariaDB 10.3.27.
    Thank you, Best.
  • Patacas
    • Dec 2021
    Enter password:
    Thank you, Best.
    The problem is in the way you created the database, for sure you put something like this "create database data_zabbix character set utf8mb4 collate utf8mb4_bin;"
    You must use the utf8 collate utf8_bin so that the import of the schema work.
    SOLUCION:
    create database database_zabbix character set utf8 collate utf8_bin;
    Best regrads,
    LM
