Zabbix 5.2 does not support calculated items in template
  • nicolasgoudard
    • Mar 2021
    • 27
    Hello
    I use Zabbix 5.2
    I want create a calculated item in my custom template.
    I put screenshots :
    In item panel, in the formula field, If I put a my template name or the real template parent that provides the item it does not work when I press the test button : it tells that the value does not exist . But If I put the host itself, it is working
    the latest data panel is not populated by the value of the calculated items (...cpu (num)
    The documentation tells that we can use a template name but it does not work https://www.zabbix.com/documentation...pes/calculated
    So how can I create a calculated item in my template ?
    best regards
Name:	Capture d’écran 2021-03-18 à 11.33.18.png
ID:	420931 Click image for larger version
Name:	Capture d’écran 2021-03-18 à 11.49.19.png
ID:	420932 Zabbix does not support calculated items in template
    In lastest values, the calculated item are not updated
