my configure options like this:
./configure --prefix=/home/zabbix/zserver --enable-server --enable-agent --with-net-snmp --with-libcurl --with-libxml2 --with-ssh2 --with-oracle=$ORACLE_HOME --with-oracle-include=usr/lib/oracle/11.2/client --with-oracle-lib=/usr/lib/oracle/11.2/client/lib
i already install oci8,zabbix and oracle are installed on same server
when i start zabbix,the log display
7430:20150622:004527.159 ****** Enabled features ******
7430:20150622:004527.159 SNMP monitoring: YES
7430:20150622:004527.159 IPMI monitoring: NO
7430:20150622:004527.159 WEB monitoring: YES
7430:20150622:004527.159 VMware monitoring: YES
7430:20150622:004527.159 Jabber notifications: NO
7430:20150622:004527.159 Ez Texting notifications: YES
7430:20150622:004527.160 ODBC: NO
7430:20150622:004527.160 SSH2 support: YES
7430:20150622:004527.160 IPv6 support: NO
7430:20150622:004527.160 ******************************
7430:20150622:004527.160 using configuration file: /home/zabbix/zserver/etc/zabbix_server.conf
7430:20150622:004527.168 [Z3001] connection to database '//localhost:1521/zabbix' failed: [-1]
7430:20150622:004527.169 Cannot connect to the database. Exiting...
what's the code [-1] means ? how can i fix this problem ??
thank you all~
thank you all~
