I'm having strange problem with performance counters.
I've got zabbix serwer, 5.2 version and 2 machines that are using Windows 10.
I'm using standard Windows templates but I've got a problem with CPU Utilization.
On other machine everything is working great, but on first machine after restart I'm receiving information from zabbix agent:
I've tried to reset performance counters with no effect.... ( lodctr /R and winmgmt.exe /resyncperf)
Can You help me?
I'm using zabbix for more than 1 year and always reset performance counters solved the problem
I don't know why it's not working...
If You need more info please write. I'll try to provide it.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,0 utilization: The specified object was not found on the computer.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,1 utilization: The specified object was not found on the computer.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,2 utilization: The specified object was not found on the computer.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,3 utilization: The specified object was not found on the computer.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,4 utilization: The specified object was not found on the computer.
2021/03/23 12:46:47.017050 [Cpu] cannot add performance counter for CPU#0,5 utilization: The specified object was not found on the computer.
Can You help me?
