Remote command failing
  • Mark Thornton
    • Jun 2015
    I'm using Zabbix 2.2 on Ubuntu 14.04 and on our newest machines system.run[command] is failing when the command takes longer than echo hello to execute. I can run the command on the machine as 'zabbix' and it takes under a second, but if run via the zabbix agent it sits in the process list doing nothing until the timeout is reached.
    The machines on which it fails are about 3 times faster than the fastest of those on which it works (i7-5820 vs i5-2400, 6 core + hyperthreading vs 4 core).
    I have run out of ideas as to what do with this.
    An example of a command which fails is
    /usr/lib/update-notifier/apt-check
    (reports number of packages which can be updated).
  • Mark Thornton
    • Jun 2015
    The simplest command which fails is
    lsb_release -s -d
    while
    df -h
    succeeds
    For now my workaround is to create a cron job which writes the answers to a series of files. Zabbix agent then retrieves the content of the files with vfs.file.contents.
    • bbrendon
      • Sep 2005
      • 873
      Maybe the agent is running as a user with bad permissions or environment?
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • Mark Thornton
        • Jun 2015
        A user or environment in which lsb_release fails?
        It is running under the zabbix user account (as standard). I have not been able to identify anything unusual or different from the machines on which it works.
