[Cpu] cannot add performance counter for total CPU utilization zabbix agent2 5.0.9
  • zar
    • Mar 2018
    • 148
    Using the system.cpu.util parameter on 2008r2 servers - it works fine. (the agent is still old there)
    But on Agent2 it is impossible to get metrics, it gives 0.000000.
    $ zabbix_get -s PCname -k system.cpu.util --tls-connect=psk --tls-psk-identity="...." --tls-psk-file=/home/me/zabbix_gent.psk
    0.000000
    $ zabbix_get -s serverName -k system.cpu.util --tls-connect=psk --tls-psk-identity="...." --tls-psk-file=/home/me/zbx_srv.psk
    3.080957
    in the agent logs only errors of the type:
    2021/04/07 13:51:40.961072 Starting Zabbix Agent 2 []. (5.0.9)
    2021/04/07 13:51:40.997723 OpenSSL library (OpenSSL 1.1.1d 10 Sep 2019) initialized
    2021/04/07 13:51:40.997723 default context ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    2021/04/07 13:51:40.997723 psk context ciphersuites: TLS_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 ECDHE-PSK-AES128-CBC-SHA256 ECDHE-PSK-AES128-CBC-SHA PSK-AES128-GCM-SHA256 PSK-AES128-CCM8 PSK-AES128-CCM PSK-AES128-CBC-SHA256 PSK-AES128-CBC-SHA
    2021/04/07 13:51:40.997723 using configuration file: C:\Program Files\Zabbix Agent 2\zabbix_agent2.conf
    2021/04/07 13:51:41.019005 using plugin 'Agent' providing following interfaces: exporter
    2021/04/07 13:51:41.019005 using plugin 'Ceph' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.019005 using plugin 'Cpu' providing following interfaces: exporter, collector, runner
    2021/04/07 13:51:41.020187 using plugin 'File' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.020187 using plugin 'Log' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.020187 using plugin 'Memcached' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.020187 using plugin 'Memory' providing following interfaces: exporter
    2021/04/07 13:51:41.020187 using plugin 'Mysql' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.020187 using plugin 'NetIf' providing following interfaces: exporter
    2021/04/07 13:51:41.020187 using plugin 'Oracle' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.020187 using plugin 'Postgres' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.020187 using plugin 'Proc' providing following interfaces: exporter
    2021/04/07 13:51:41.020187 using plugin 'Redis' providing following interfaces: exporter, runner, configurator
    2021/04/07 13:51:41.020187 using plugin 'Smart' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.020187 using plugin 'Swap' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'SystemRun' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'TCP' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'UDP' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'Uname' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'Uptime' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'UserParameter' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'Users' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'VfsFs' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'Web' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'WindowsEventlog' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.021369 using plugin 'WindowsPerfInstance' providing following interfaces: exporter
    2021/04/07 13:51:41.021369 using plugin 'WindowsPerfMon' providing following interfaces: exporter, collector, runner
    2021/04/07 13:51:41.021369 using plugin 'WindowsServices' providing following interfaces: exporter
    2021/04/07 13:51:41.022551 using plugin 'Wmi' providing following interfaces: exporter
    2021/04/07 13:51:41.022551 using plugin 'ZabbixAsync' providing following interfaces: exporter
    2021/04/07 13:51:41.022551 using plugin 'ZabbixStats' providing following interfaces: exporter, configurator
    2021/04/07 13:51:41.022551 using plugin 'ZabbixSync' providing following interfaces: exporter
    2021/04/07 13:51:43.327905 starting manager
    2021/04/07 13:51:44.225250 [0] processing update request (1 requests)
    2021/04/07 13:51:44.225250 [0] registering new client
    2021/04/07 13:51:44.225250 [0] adding new request for key: 'system.hostname'
    2021/04/07 13:51:44.225250 [0] created direct exporter task for plugin 'Uname' itemid:0 key 'system.hostname'
    2021/04/07 13:51:44.225250 executing direct exporter task for key 'system.hostname'
    2021/04/07 13:51:44.225250 executed direct exporter task for key 'system.hostname'
    2021/04/07 13:51:44.226550 [101] starting memory cache
    2021/04/07 13:51:44.226550 [101] starting server connector for '10.202.100.150:10051'
    2021/04/07 13:51:44.230452 [0] starting listener for '0.0.0.0:10050'
    2021/04/07 13:51:44.234353 listening for control connections on \\.\pipe\agent.sock
    2021/04/07 13:51:45.558262 [101] In refreshActiveChecks() from [10.202.100.150:10051]
    2021/04/07 13:51:45.580371 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:51:45.619386 [101] End of refreshActiveChecks() from [10.202.100.150:10051]
    2021/04/07 13:51:45.619386 [101] processing update request (8 requests)
    2021/04/07 13:51:45.619386 [101] registering new client
    2021/04/07 13:51:45.619386 [101] adding new request for key: 'eventlog[Security,,,,1102,,]'
    2021/04/07 13:51:45.647997 [101] created exporter task for plugin 'WindowsEventlog' itemid:56340 key 'eventlog[Security,,,,1102,,]'
    2021/04/07 13:51:45.647997 [101] created configurator task for plugin WindowsEventlog
    2021/04/07 13:51:45.647997 [101] adding new request for key: 'eventlog[Security,,,,4720,,]'
    2021/04/07 13:51:45.647997 [101] created exporter task for plugin 'WindowsEventlog' itemid:56341 key 'eventlog[Security,,,,4720,,]'
    2021/04/07 13:51:45.649297 [101] adding new request for key: 'eventlog[Security,,,,4722,,]'
    2021/04/07 13:51:45.649297 [101] created exporter task for plugin 'WindowsEventlog' itemid:56342 key 'eventlog[Security,,,,4722,,]'
    2021/04/07 13:51:45.649297 [101] adding new request for key: 'eventlog[Security,,,,4724,,]'
    2021/04/07 13:51:45.649297 [101] created exporter task for plugin 'WindowsEventlog' itemid:56343 key 'eventlog[Security,,,,4724,,]'
    2021/04/07 13:51:45.649297 [101] adding new request for key: 'eventlog[Security,,,,4725,,]'
    2021/04/07 13:51:45.649297 [101] created exporter task for plugin 'WindowsEventlog' itemid:56344 key 'eventlog[Security,,,,4725,,]'
    2021/04/07 13:51:45.649297 [101] adding new request for key: 'eventlog[Security,,,,4726,,]'
    2021/04/07 13:51:45.649297 [101] created exporter task for plugin 'WindowsEventlog' itemid:56345 key 'eventlog[Security,,,,4726,,]'
    2021/04/07 13:51:45.650598 [101] adding new request for key: 'eventlog[Security,,,,4739,,]'
    2021/04/07 13:51:45.650598 [101] created exporter task for plugin 'WindowsEventlog' itemid:56346 key 'eventlog[Security,,,,4739,,]'
    2021/04/07 13:51:45.650598 [101] adding new request for key: 'eventlog[Security,,,,4767,,]'
    2021/04/07 13:51:45.650598 [101] created exporter task for plugin 'WindowsEventlog' itemid:56347 key 'eventlog[Security,,,,4767,,]'
    2021/04/07 13:51:45.650598 plugin WindowsEventlog: executing configurator task
    2021/04/07 13:52:20.611319 unsupported windows service command received
    2021/04/07 13:52:39.541069 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:52:39.541069 received passive check request: 'system.cpu.util' from '10.202.100.150'
    2021/04/07 13:52:39.542112 [1] processing update request (1 requests)
    2021/04/07 13:52:39.542112 [1] registering new client
    2021/04/07 13:52:39.542112 [1] adding new request for key: 'system.cpu.util'
    2021/04/07 13:52:39.542112 [1] created collector task for plugin Cpu with collecting interval 1
    2021/04/07 13:52:39.542112 [1] created direct exporter task for plugin 'Cpu' itemid:0 key 'system.cpu.util'
    2021/04/07 13:52:39.542112 [1] created starter task for plugin Cpu
    2021/04/07 13:52:39.542112 plugin Cpu: executing starter task
    2021/04/07 13:52:39.547326 [Cpu] cannot add performance counter for total CPU utilization: ╨г╨║╨░╨╖╨░╨╜╨╜╤Л╨╡ ╨╛╨▒╤К╨╡╨║╤В╤Л ╨╜╨╡ ╨╜╨░╨╣╨┤╨╡╨╜╤Л ╨╜╨░ ╤Н╤В╨╛╨╝ ╨║╨╛╨╝╨┐╤М╤О╤В╨╡╤А╨╡.
    2021/04/07 13:52:39.547326 [Cpu] cpu_groups = 1, cpus_per_group = 3, cpus = 3
    2021/04/07 13:52:39.550455 [Cpu] cannot add performance counter for CPU#0,0 utilization: ╨г╨║╨░╨╖╨░╨╜╨╜╤Л╨╡ ╨╛╨▒╤К╨╡╨║╤В╤Л ╨╜╨╡ ╨╜╨░╨╣╨┤╨╡╨╜╤Л ╨╜╨░ ╤Н╤В╨╛╨╝ ╨║╨╛╨╝╨┐╤М╤О╤В╨╡╤А╨╡.
    2021/04/07 13:52:39.553584 [Cpu] cannot add performance counter for CPU#0,1 utilization: ╨г╨║╨░╨╖╨░╨╜╨╜╤Л╨╡ ╨╛╨▒╤К╨╡╨║╤В╤Л ╨╜╨╡ ╨╜╨░╨╣╨┤╨╡╨╜╤Л ╨╜╨░ ╤Н╤В╨╛╨╝ ╨║╨╛╨╝╨┐╤М╤О╤В╨╡╤А╨╡.
    2021/04/07 13:52:39.554626 [Cpu] cannot add performance counter for CPU#0,2 utilization: ╨г╨║╨░╨╖╨░╨╜╨╜╤Л╨╡ ╨╛╨▒╤К╨╡╨║╤В╤Л ╨╜╨╡ ╨╜╨░╨╣╨┤╨╡╨╜╤Л ╨╜╨░ ╤Н╤В╨╛╨╝ ╨║╨╛╨╝╨┐╤М╤О╤В╨╡╤А╨╡.
    2021/04/07 13:52:39.554626 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:39.554626 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:40.151165 plugin Cpu: executing collector task
    2021/04/07 13:52:40.154294 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:40.154294 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:41.219095 plugin Cpu: executing collector task
    2021/04/07 13:52:41.222224 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:41.222224 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:42.287024 plugin Cpu: executing collector task
    2021/04/07 13:52:42.290153 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:42.290153 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:52:42.290153 sending passive check response: '0.000000' to '10.202.100.150'
    2021/04/07 13:52:42.504991 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:52:42.506033 received passive check request: 'vfs.fs.size[C:,free]' from '10.202.100.150'
    2021/04/07 13:52:42.506033 [1] processing update request (1 requests)
    2021/04/07 13:52:42.506033 [1] adding new request for key: 'vfs.fs.size[C:,free]'
    2021/04/07 13:52:42.506033 [1] created direct exporter task for plugin 'VfsFs' itemid:0 key 'vfs.fs.size[C:,free]'
    2021/04/07 13:52:42.507076 executing direct exporter task for key 'vfs.fs.size[C:,free]'
    2021/04/07 13:52:42.507076 executed direct exporter task for key 'vfs.fs.size[C:,free]'
    2021/04/07 13:52:42.507076 sending passive check response: '10054610944' to '10.202.100.150'
    2021/04/07 13:52:43.354954 plugin Cpu: executing collector task
    2021/04/07 13:52:44.422884 plugin Cpu: executing collector task
    2021/04/07 13:52:45.490813 plugin Cpu: executing collector task
    2021/04/07 13:52:46.546853 plugin Cpu: executing collector task
    021/04/07 13:55:20.738655 plugin Cpu: executing collector task
    2021/04/07 13:55:21.943084 plugin Cpu: executing collector task
    2021/04/07 13:55:23.147513 plugin Cpu: executing collector task
    2021/04/07 13:55:23.586236 unsupported windows service command received
    2021/04/07 13:55:24.351942 plugin Cpu: executing collector task
    2021/04/07 13:55:25.543199 plugin Cpu: executing collector task
    2021/04/07 13:55:26.627206 plugin Cpu: executing collector task
    2021/04/07 13:55:27.711212 plugin Cpu: executing collector task
    2021/04/07 13:55:28.795219 plugin Cpu: executing collector task
    2021/04/07 13:55:29.879225 plugin Cpu: executing collector task
    2021/04/07 13:55:30.587428 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:55:30.588487 received passive check request: 'system.cpu.util' from '10.202.100.150'
    2021/04/07 13:55:30.588487 [1] processing update request (1 requests)
    2021/04/07 13:55:30.588487 [1] adding new request for key: 'system.cpu.util'
    2021/04/07 13:55:30.589546 [1] created direct exporter task for plugin 'Cpu' itemid:0 key 'system.cpu.util'
    2021/04/07 13:55:30.589546 plugin Cpu: executing collector task
    2021/04/07 13:55:30.591663 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:30.591663 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:30.591663 sending passive check response: '0.000000' to '10.202.100.150'
    2021/04/07 13:55:31.258581 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:55:31.259639 received passive check request: 'system.cpu.util' from '10.202.100.150'
    2021/04/07 13:55:31.259639 [1] processing update request (1 requests)
    2021/04/07 13:55:31.260698 [1] adding new request for key: 'system.cpu.util'
    2021/04/07 13:55:31.260698 [1] created direct exporter task for plugin 'Cpu' itemid:0 key 'system.cpu.util'
    2021/04/07 13:55:31.260698 plugin Cpu: executing collector task
    2021/04/07 13:55:31.262815 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:31.262815 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:31.262815 sending passive check response: '0.000000' to '10.202.100.150'
    2021/04/07 13:55:31.773060 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:55:31.773060 received passive check request: 'system.cpu.util' from '10.202.100.150'
    2021/04/07 13:55:31.773060 [1] processing update request (1 requests)
    2021/04/07 13:55:31.774119 [1] adding new request for key: 'system.cpu.util'
    2021/04/07 13:55:31.774119 [1] created direct exporter task for plugin 'Cpu' itemid:0 key 'system.cpu.util'
    2021/04/07 13:55:31.774119 executing direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:31.774119 executed direct exporter task for key 'system.cpu.util'
    2021/04/07 13:55:31.774119 sending passive check response: '0.000000' to '10.202.100.150'
    2021/04/07 13:55:32.047238 plugin Cpu: executing collector task
    2021/04/07 13:55:33.131244 plugin Cpu: executing collector task
    2021/04/07 13:55:34.216309 plugin Cpu: executing collector task
    2021/04/07 13:55:35.331015 plugin Cpu: executing collector task
    2021/04/07 13:55:36.371403 plugin Cpu: executing collector task
    2021/04/07 13:55:37.346967 plugin Cpu: executing collector task
    2021/04/07 13:55:38.322532 plugin Cpu: executing collector task
    2021/04/07 13:55:39.298097 plugin Cpu: executing collector task
    2021/04/07 13:55:40.273662 plugin Cpu: executing collector task
    2021/04/07 13:55:41.249227 plugin Cpu: executing collector task
    2021/04/07 13:55:41.604584 connection established using TLSv1.2 PSK-AES128-CBC-SHA
    2021/04/07 13:55:41.604584 received passive check request: 'vfs.fs.size[C:,free]' from '10.202.100.150'
    2021/04/07 13:55:41.604584 [1] processing update request (1 requests)
    2021/04/07 13:55:41.604584 [1] adding new request for key: 'vfs.fs.size[C:,free]'
    2021/04/07 13:55:41.604584 [1] created direct exporter task for plugin 'VfsFs' itemid:0 key 'vfs.fs.size[C:,free]'
    2021/04/07 13:55:41.604584 executing direct exporter task for key 'vfs.fs.size[C:,free]'
    2021/04/07 13:55:41.605536 executed direct exporter task for key 'vfs.fs.size[C:,free]'
    2021/04/07 13:55:41.605536 sending passive check response: '10053189632' to '10.202.100.150'
    2021/04/07 13:55:42.224791 plugin Cpu: executing collector task
    2021/04/07 13:55:43.200356 plugin Cpu: executing collector task
    2021/04/07 13:55:44.175921 plugin Cpu: executing collector task
    2021/04/07 13:55:45.151486 plugin Cpu: executing collector task
    2021/04/07 13:55:46.116377 plugin Cpu: executing collector task
    help what's wrong? there is a load on the processor....
