For some reason I am not able to upgrade from 5.0 tot 5.2 on Ubuntu 16.04. Normally it is quite easy. Maybe somebody can give me advice?
Ubuntu 16.04 with PHP 7.4.16 installed and running. Currently fine on Zabbix 5.0. When I add the new repositories and do a apt update & apt upgrade nothing happens. When I try to manually update zabbix-server-mysql, following notification is shown: zabbix-server-mysql is already the newest version (1:5.0.10-1+xenial).
For some reason I also have to use zabbix-frontend-deprecated. When I switch over to the normal version it will install the frontend with version 2.4....
Any clue as I am stuk :-(
