Instalation Zabbix 5.0 on Amazon Linux 2
  • linuxmall
    • Apr 2021
    Hi Erveryone,
    I have difficulty installing Zabbix 5.0 on Amazon Linux 2.
    Problem: is, a dependency of software.
    Step 1
    root@zabbix-srv ~]# rpm -Uvh https://repo.zabbix.com/zabbix/5.0/rhel/7/x86_64/zabbix-release-5.0-1.el7.noarch.rpm
    Retrieving https://repo.zabbix.com/zabbix/5.0/rhel/7/x86_64/zabbix-release-5.0-1.el7.noarch.rpm
    warning: /var/tmp/rpm-tmp.9lKrIS: Header V4 RSA/SHA512 Signature, key ID a14fe591: NOKEY
    Preparing... ################################# [100%]
    Updating / installing...
    1:zabbix-release-5.0-1.el7 ################################# [100%]
    Step 2
    [root@zabbix-srv ~]# yum clean all
    Loaded plugins: priorities, update-motd, upgrade-helper
    Cleaning repos: amzn-main amzn-updates zabbix zabbix-non-supported
    Cleaning up everything
    Step 3 - Error
    [root@zabbix-srv ~]# yum install zabbix-server-mysql zabbix-agent
    amzn-main | 2.1 kB 00:00:00
    amzn-updates | 3.8 kB 00:00:00
    zabbix | 2.9 kB 00:00:00
    zabbix-non-supported | 951 B 00:00:00
    (1/6): amzn-main/latest/group_gz | 4.4 kB 00:00:00
    (2/6): amzn-updates/latest/group_gz | 4.4 kB 00:00:00
    (3/6): amzn-updates/latest/updateinfo | 728 kB 00:00:00
    (4/6): amzn-main/latest/primary_db | 4.0 MB 00:00:00
    (5/6): amzn-updates/latest/primary_db | 4.5 MB 00:00:00
    (6/6): zabbix/x86_64/primary_db | 100 kB 00:00:01
    zabbix-non-supported/x86_64/primary | 1.6 kB 00:00:00
    zabbix-non-supported 4/4
    1 packages excluded due to repository priority protections
    Resolving Dependencies
    --> Running transaction check
    ---> Package zabbix-agent.x86_64 0:5.0.10-1.el7 will be installed
    --> Processing Dependency: systemd for package: zabbix-agent-5.0.10-1.el7.x86_64
    --> Processing Dependency: libpcre.so.1()(64bit) for package: zabbix-agent-5.0.10-1.el7.x86_64
    ---> Package zabbix-server-mysql.x86_64 0:5.0.10-1.el7 will be installed
    --> Processing Dependency: fping for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libmysqlclient.so.18(libmysqlclient_18)(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: systemd for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libmysqlclient.so.18()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libnetsnmp.so.31()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libOpenIPMIposix.so.0()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libpcre.so.1()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libOpenIPMI.so.0()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    --> Processing Dependency: libodbc.so.2()(64bit) for package: zabbix-server-mysql-5.0.10-1.el7.x86_64
    ---> Package OpenIPMI-libs.x86_64 0:2.0.16-14.13.amzn1 will be installed
    ---> Package fping.x86_64 0:2.4b2-10.0.amzn1 will be installed
    ---> Package mysql55-libs.x86_64 0:5.5.62-1.23.amzn1 will be installed
    ---> Package unixODBC.x86_64 0:2.2.14-14.7.amzn1 will be installed
    --> Processing Dependency: libltdl.so.7()(64bit) for package: unixODBC-2.2.14-14.7.amzn1.x86_64
    ---> Package libtool-ltdl.x86_64 0:2.4.2-20.4.8.5.32.amzn1 will be installed
    --> Finished Dependency Resolution
    Error: Package: zabbix-server-mysql-5.0.10-1.el7.x86_64 (zabbix)
    Requires: libpcre.so.1()(64bit)
    Error: Package: zabbix-agent-5.0.10-1.el7.x86_64 (zabbix)
    Requires: systemd
    Requires: libnetsnmp.so.31()(64bit)
    Requires: systemd
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    My SO: Amazon Linux 2
    Kernel:
    [root@zabbix-srv]# uname -r
    4.14.225-121.362.amzn1.x86_64
    Please, could someone help me?
    • 4996
    Install required thing and try again... ?
