Hello Everyone,
I am new to Zabbix forum. I am currently working on setting up zabbix monitoring set up in the containers. I have successfully build custom docker image for the Zabbix server. However, I have some issues in doing the same for the Zabbix front end. I followed the instructions available here to set up the front end. However, I am unable to access the front end. It gives the below error when I hit the zabbix front end http://<IP>/zabbix
Network Error (tcp_error) A communication error occurred: "Connection refused" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time.
I tried to pulled down the docker file, configs and script available here and update the docker-entrypoint.sh script with all the information like zabbix db host, user, password etc. And After starting the container I ended up in the same error.
I am not sure if there is any know issue or I am doing something wrong here.
Any help on this is much appreciated.
Regards,
