i am having trouble to enable the connection between out zabbix 5.0 server and the zabbix java gateway.
The "JMX" status icon displays this message:
Unsupported or unrecognized SSL message: service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi
I have increased the logging level of the gateway and this is appearing in the logs
The JMX interface is set up like this:
This seems to be working as i can connect to xx.yy.zz.124:8099 without SSL using JConsole.
Im not sure if the problem appears between Zabbix Server and the Gateway or between the gateway and the Java application.
I haven't found any clues on
how the gateway knows how to find the Java appications JMX interface
if the gateway connects via PID or IP / Portnumber
where to configure those in the gateway
how to control if the communication between zabbix server and the gateway is encrypted
I would be okay with unencrypted connections
In the host configuration on the zabbix server if have tried the following settings under the encryption tab
No encryption = On, PSK = Off
No encryption = Off, PSK = On
No encryption = On, PSK = On
The PSK encryption was working fine between Zabbix Server and the zabbx agent.
Any help would be appreciated,
thanks in advance
Jens
2021-04-19 10:16:03.034 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection
2021-04-19 10:16:03.035 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
2021-04-19 10:16:03.035 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 8 bytes of data length
2021-04-19 10:16:03.035 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 191 bytes of request data
2021-04-19 10:16:03.035 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - received the following data in request: {"request":"java gateway jmx","jmx_endpoint":"service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi","keys":["jmx[\"java.lang:type=GarbageCollector,name=ParNew\",Co llectionTime]"]}
2021-04-19 10:16:03.036 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - RMI SSL hint cache cleanup is scheduled on 1618903451644, now is: 1618820163036
2021-04-19 10:16:03.036 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
2021-04-19 10:16:03.036 [pool-2-thread-4] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi'
2021-04-19 10:16:03.039 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection
2021-04-19 10:16:03.039 [pool-2-thread-5] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
2021-04-19 10:16:03.040 [pool-2-thread-5] WARN com.zabbix.gateway.SocketProcessor - error processing request: bad protocol header: 4A 52 4D 49 00
2021-04-19 10:16:03.040 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
com.zabbix.gateway.ZabbixException: bad protocol header: 4A 52 4D 49 00
at com.zabbix.gateway.BinaryProtocolSpeaker.getReques t(BinaryProtocolSpeaker.java:59)
at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:57)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
2021-04-19 10:16:03.040 [pool-2-thread-5] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"bad protocol header: 4A 52 4D 49 00"}
2021-04-19 10:16:03.041 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
2021-04-19 10:16:03.041 [pool-2-thread-4] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi'
2021-04-19 10:16:03.050 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection
2021-04-19 10:16:03.050 [pool-2-thread-2] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
2021-04-19 10:16:03.060 [pool-2-thread-2] WARN com.zabbix.gateway.SocketProcessor - error processing request: bad protocol header: 16 03 03 01 94
2021-04-19 10:16:03.060 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
com.zabbix.gateway.ZabbixException: bad protocol header: 16 03 03 01 94
2021-04-19 10:16:03.060 [pool-2-thread-2] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"bad protocol header: 16 03 03 01 94"}
2021-04-19 10:16:03.060 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
2021-04-19 10:16:03.061 [pool-2-thread-4] WARN com.zabbix.gateway.SocketProcessor - error processing request, item "jmx["java.lang:type=GarbageCollector,name=ParNew",Coll ectionTime]" failed: Unsupported or unrecognized SSL message: service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi
2021-04-19 10:16:03.062 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
com.zabbix.gateway.ZabbixException: Unsupported or unrecognized SSL message: service:jmx:rmi:///jndi/rmi://our.host.com:10052/jmxrmi
at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:168)
at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:81)
2021-04-19 10:16:03.062 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"Unsupported or unrecognized SSL message: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/our.host.com:10052\/jmxrmi"}
2021-04-19 10:16:03.062 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
CATALINA_OPTS="-Dcom.sun.management.jmxremote ${CATALINA_OPTS}"
CATALINA_OPTS="-Dcom.sun.management.jmxremote.port=8099 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Djava.rmi.server.hostname=xx.yy.zz.124 ${CATALINA_OPTS}"
thanks in advance
Jens
