I have an appliance that I would like to monitor via its IPMI interface. This appliance is running OpenBMC Linux firmware.
I have successfully added the host, set up IPMI authentication (Auth algorithm: RMPC+ , Privilege: Admin) the interface is up,
I have added the official template so the automatic discovery of sensors can happen but it returns an empty list. I have manually
added a few items (sensors) which I know for sure they exist, but zabbix says 'sensor or control does not exist'.
I have tried to prefix them like "id:" and "name:" but they made no difference. I also tried suffixing the sensors IDs with 0 as some of the OpenIPMI implementations differ but that made no change either.
If I manually run "ipmitool sensor" command on the Zabbix proxy (from where this host is monitored) it returns all the sensors correctly. If I run "ipmitool sensor powersupply0" or "ipmitool sensor fan0_0" they return correct answer.
I am a bit puzzled at this stage and trying to understand what is failing and why.
Thanks!
Here are Zabbix Proxy logs at DebugLevel=4
Here are the logs from command line
Component versions:
Thanks!
6493:20210419:112950.767 In ipmi_poller_process_value_request() 6493:20210419:112950.767 ipmi_poller_process_value_request() for discovery itemid:411949 addr:bmc001.test.net port:623 authtype:6 privilege:4 username:root 6493:20210419:112950.767 In get_discovery_ipmi() itemid:411949 6493:20210419:112950.767 In zbx_init_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:112950.767 In zbx_get_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:112950.767 End of zbx_get_ipmi_host():(nil) 6493:20210419:112950.767 In zbx_allocate_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:112950.767 End of zbx_allocate_ipmi_host():0x55aa9ee85450 6493:20210419:112950.769 In zbx_perform_openipmi_ops() host:'[bmc001.test.net]:623' phost:0x55aa9ee85450 from zbx_init_ipmi_host() 6493:20210419:112950.850 INFO: 0 0 ipmi_lan.c(connection_up): Connection 0 to the BMC is up 6493:20210419:112950.850 INFO: 0 0 ipmi_lan.c(connection_up): Connection to the BMC restored 6481:20210419:112950.861 In DCconfig_get_ipmi_poller_items() 6481:20210419:112950.861 End of DCconfig_get_ipmi_poller_items():0 6493:20210419:112951.112 End zbx_perform_openipmi_ops() from zbx_init_ipmi_host() 6493:20210419:112951.112 End of zbx_init_ipmi_host():0x55aa9ee85450 domain_nr:0 6493:20210419:112951.112 End of get_discovery_ipmi() value:[] 6493:20210419:112951.112 End of ipmi_poller_process_value_request() 6493:20210419:113818.812 In ipmi_poller_process_value_request() 6493:20210419:113818.812 ipmi_poller_process_value_request() itemid:412098 addr:bmc001.test.net port:623 authtype:6 privilege:4 username:root sensor:powersupply0 6493:20210419:113818.812 In get_value_ipmi() itemid:412098 6493:20210419:113818.812 In zbx_init_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:113818.812 In zbx_get_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:113818.812 End of zbx_get_ipmi_host():0x55aa9ee85450 6493:20210419:113818.812 End of zbx_init_ipmi_host():0x55aa9ee85450 domain_nr:0 6493:20210419:113818.812 In zbx_get_ipmi_sensor_by_id() sensor:'powersupply0@[bmc001.test.net]:623' 6493:20210419:113818.812 End of zbx_get_ipmi_sensor_by_id():(nil) 6493:20210419:113818.812 In zbx_get_ipmi_control_by_name() control: powersupply0@[bmc001.test.net]:623 6493:20210419:113818.812 End of zbx_get_ipmi_control_by_name():(nil) 6493:20210419:113818.813 End of ipmi_poller_process_value_request() 6493:20210419:113818.813 In ipmi_poller_process_value_request() 6493:20210419:113818.813 ipmi_poller_process_value_request() itemid:412098 addr:bmc001.test.net port:623 authtype:6 privilege:4 username:root sensor:fan0_0 6493:20210419:113818.813 In get_value_ipmi() itemid:412098 6493:20210419:113818.813 In zbx_init_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:113818.813 In zbx_get_ipmi_host() host:'[bmc001.test.net]:623' 6493:20210419:113818.813 End of zbx_get_ipmi_host():0x55aa9ee85450 6493:20210419:113818.813 End of zbx_init_ipmi_host():0x55aa9ee85450 domain_nr:0 6493:20210419:113818.813 In zbx_get_ipmi_sensor_by_id() sensor:'fan0_0@[bmc001.test.net]:623' 6493:20210419:113818.813 End of zbx_get_ipmi_sensor_by_id():(nil) 6493:20210419:113818.813 In zbx_get_ipmi_control_by_name() control: fan0_0@[bmc001.test.net]:623 6493:20210419:113818.813 End of zbx_get_ipmi_control_by_name():(nil) 6493:20210419:113818.813 End of ipmi_poller_process_value_request()
# ipmitool -I lanplus -U root -P <password> -H bmc001.test.net sensor | grep power powersupply0 | 0x0 | discrete | 0x0100| na | na | na | na | na | na powersupply1 | 0x0 | discrete | 0x0100| na | na | na | na | na | na # ipmitool -I lanplus -U root -P <password> -H bmc001.test.net sensor | grep fan0_0 fan0_0 | 500.000 | RPM | ok | na | 6900.000 | 7700.000 | 3800.000 | 5200.000 | na # ipmitool -I lanplus -U root -P <password> -H bmc001.test.net sensor get powersupply0 Locating sensor record... Sensor ID : powersupply0 (0x9) Entity ID : 10.1 Sensor Type (Discrete): Power Supply States Asserted : Power Supply [Presence detected] # ipmitool -I lanplus -U root -P <password> -H bmc001.test.net sensor sensor get fan0_0 Locating sensor record... Sensor ID : fan0_0 (0x32) Entity ID : 29.1 Sensor Type (Threshold) : Fan Sensor Reading : 600 (+/- 0) RPM Status : ok Lower Non-Recoverable : na Lower Critical : 6900.000 Lower Non-Critical : 7700.000 Upper Non-Critical : 3800.000 Upper Critical : 5200.000 Upper Non-Recoverable : na Positive Hysteresis : Unspecified Negative Hysteresis : Unspecified
# rpm -qa | grep zabbix zabbix-agent2-5.0.10-1.el7.x86_64 zabbix-proxy-sqlite3-5.0.0-1.el7.x86_64 # rpm -qa | grep -i openipmi OpenIPMI-2.0.27-1.el7.x86_64 OpenIPMI-libs-2.0.27-1.el7.x86_64 OpenIPMI-modalias-2.0.27-1.el7.x86_64 # rpm -qa | grep -i ipmitool ipmitool-1.8.18-7.el7.x86_64
