Custom multipler in preprocessing using xml template
  • shilpab
    • Jun 2020
    • 17
    I want to add a custom multiplier "0.1" to all the items in a xml template for zabbix 5.0. I am using the below template for an item, but it does not give any preprocessing value when i import the template.Can anyone help me in this please.
    <preprocessing>
    <step>
    </type> MULTIPLIER </type>
    <params>0.1</paramas>
    </step>
    </preprocessing>
  • shilpab
    • Jun 2020
    • 17
    Thanks for the reply.
    I have a complete XML file with items and triggers for zabbix 5.0 version. This is going to be just a part for each item.
    And i also have xml for zabbix 3.0 version in which the preprocessing is not supported. How can i give the custom multiplier like" 0.1" in the xml?
    • shilpab
      • Jun 2020
      • 17
      Thank you, But does the same code work zabbix version 3 also?
      As per i know version 3 supports only integer multiplication.
        • 4996
        This does not seem to be a template, but just a step you need to add to template, to each item. It does not work this way, that you add only preprocessing into "template" and hope it applies to all items already present...
          • 4996
          You need to add it to each items config...
          <items>
          <item>
          <name>your item</name>
          <key>your key</key>
          <history>1h</history>
          <trends>0</trends>
          <value_type>type</value_type>
          <description>description </description>
          <applications>
          <application>
          <name>your app name</name>
          </application>
          </applications>
          <preprocessing>
          <step>
          </step>
          </preprocessing>
          </item>
          <item>
          </item>
          </items>
