I tried to use an SSL connection in a web scenarios, but without success.
The result is that zabbix report errors below, but their cause is not very clear to me.
I even tried to set up proxy (squid) and error is different, but the result is the same.
I tried to increase logging by using the following command, but nothing new to see.
zabbix_server --runtime-control log_level_increase="http poller"
I would expect that the problem is due to the server self-signed certificate, but with curl, wget, links and other system tools I solved it by "adding" certificate in /etc/ssl/certs/ but it did not help to zabbix.
Error without proxy server:
cannot process step "home" of web scenario "test" on host "server": SSL connect error: gnutls_handshake() failed: Error in the pull function.
Error with proxy server:
cannot process step "home" of web scenario "test" on host "server": SSL connect error: gnutls_handshake() failed: The TLS connection was non-properly terminated.
Finally, I created external check script with curl, but I don’t like this solution, especially if I wanted to use more complex scenarios.
I have installed zabbix:2.4.5 (revision 53282) on Debian.
Does anybody have a clue what I should look at?
Thank you very much for any information.
