Zabbix Items not polling at set interval
  • grantav
    • Dec 2013
    Hi Guys
    I have an older zabbix machine running on Zabbix 2.0.11 (centos 6.4, mysql). We are moving to a new Datacentre so I spun up a new instance running Zabbix 2.4.5(centos 6.6, mysql) at the new Data Centre.
    So I have 2 machines monitoring partially the same things until I have moved everything across. The servers I am monitoring are located in the same data centre as the new zabbix instance, the new DC.
    My issue is that the items(zabbix agent user parameters - light weight cat and cut of textfile) on the new instance appears to only be logging every 180s instead of every 60s. Config of the items are exactly the same on both machines. They where exported from the old and imported into the new. I have since redone some of the items by hand just in case it was a capability or format issue.
    I've attached some screenshots if the what I am talking about. Is it worth starting over again with zabbix 3?
    Lemme know what you guys think.
