How is trend data calculated?
  • mallyn
    • Apr 2021
    I have the problem that history data is not deleted any more. That for the DB is getting incredibly huge. I wanted to check if the trend data is calculated correctly and just the history does not get deleted or if the trend data is not getting calculated at all.
    I just cannot figure out where or how this is done. Please can someone point me in the right direction?
    Best regards
    Norbert
  • Zdenek_OMNISENSUIT
    • Nov 2020
    • 55
    Hello
    How did you recognize that history date is not deleted anymore?
    What about you housekeeper - working well?
    What means incredibly huge db?
    What about db growing speed?
    And more. ...
    omnisensuit.com
    • mallyn
      • Apr 2021
      Hello
      Because it increases in size like mad
      Yes, it runs every hour and deletes quite some items.
      from always ~450GB in 2020 it exploded to ~1TB within some weeks
      from the 1st of April to now ~300GB, which is 13GB/day
      Our DB Admin "chunked" the tables so I can see the disk size of every month, and the sizes are neary the same although retention for most items should be 1 month.
      • gofree
        • Dec 2017
        • 400
        Hi
        when it comes to trends this is how they're being calculated:
        Zabbix keeps a 1-hour max/min/avg/count set of values for each item in the table trends. The data is used for trending and long period graphs. The one hour period can not be customized.
        when it comes to housekeeper - it tries to remove 4 times the time of history etc. as the interval its being run - so in your case it will be 4hrs
        In my opinion your DB is too big for standard housekeeper and there are few recommendations that always apply for DB :
        - did you change anything related to history setting recently, number of hosts, metrics ?
        - is it a sudden increase in DB growth - something happened ..sometimes you have metrics of type "text" that are storing whole blocks of text instead of simple string, you can use preprocessing validation
        - reconfigure your metrics to strong use of preprocessing - this can save a lot of data ( all the things that are not changing frequently can be dropped , throttling ) https://www.zabbix.com/documentation.../preprocessing
        - to frequent samples ( especially without preprocessing, example 1m interval ) is a road to hell - DB will be huge - optimize
        - reasonable history, how long you store data ? the longer than bigger the DB is - optimize this paramater
        - with DB that big its time to consider partitioning instead of housekeeper ( will work fine for MySQL or Timescale - out of the box )
        • mallyn
          • Apr 2021
          Thank you very much, I will have a look at these points - especially preprocessing sounds promising
