Disk read/write
  • rodrigo.toor.rj
    • Apr 2021
    Disk read/write
    Guys, I constantly get this type of alert on Zabbix "sda: Disk read / write request responses are too high (read> 15 ms for 15m or write> 15 ms for 15)", I have been told it may be disk problems, but in several host decided to give disk problem? On hosts with a clean installation, without any service, zabbix alerts me, what can I do?
  • rodrigo.toor.rj
    • Apr 2021
    Tks Cyber, its work.
    • chimer
      • Apr 2021
      Inspite of that, I found that Zabbix 5.0.1 with mysql generates insane disk write traffic (10-20 MB/s) for only 3 standard Linux hosts. The same version with postgres does not do this.
      coomeet chatrandom omegle
      • Just_mike
        • Nov 2021
        Hi, I'm facing the same problem too. It's seems you had a resolution for that from Cyber but I can't see it anywhere?!
          • 4996
          There was... unfortunately some forum issues have caused ~500 of my posts to dissappear... still waiting for restoration by forum team...
          I think the suggestion here was to tweak those parameters to suit your environment. Disk read/write abilities depend on disk types etc. so values in out-of-the-box template might not suit everyone.
          • pkide
            • Dec 2021
            I also have that problem.
            Any news on the restoration of your forum posts? (Or if you perhaps have a clue on what parameters to tweak.)
              • 4996
              Bugging admins once in a while with the questions... Still no luck..
              But tweak your trigger conditions... They should suit your environment. so if that 15ms is normal and shoudl not trigger, set it higher, maybe 20 opr 25 is suitable for your env. Take a look on gatehred data and try to find suitable number.
                • 4996
                So you have slow disks there... Adjust trigger conditions to suitable values....
