Zabbix Agent for HP-UX 2.X doesn't send FQDN
  • clayton940
    • Jul 2014
    • 21
    I recently deployed zabbix server 2.4.5 and compiled an HP-UX agent on HP-UX 11iv3 with Zabbix Agent 2.4.5
    I have used Zabbix Server 2.2.1 and Zabbix Agent 2.0.5 as well as precompiled version and they all are exhibiting the same problem on HP-UX.
    I have created a LLD that discovers my HP-UX servers by ping.
    The node is discovered with it's FQDN.
    In the Agent if I put in Hostname=foo.domain.com
    The agent doesn't appear to speak with the Zabbix Server
    If I put in the ShortName: Hostname=foo then server presents with the following message:
    cannot send list of active checks to [x.x.x.x]: host [foo] not found
    I even created a text file called hostname.txt and used a HostnameItem=system.run[cat /tmp/hostname.txt]
    And still didn't present with the agent to the server.
    This problem isn't exhibited in Windows or Linux
  • clayton940
    • Jul 2014
    • 21
    Ok I found my problem.
    When I was adding the discovered host I was giving the ICMP template however that wasn't enough. Apparently the host needs to actually have an active check assigned to flip the indicator that the agent is in fact installed and running (Z in host display).
    • sintona
      • Apr 2016
      • 11
      Can you please help me how to install agent on HP Unix? i am struggling to findout a proper method. my HP-UX version is 11.31.
