I'm trying to create a host item. After a while there was a message "Get value from agent failed: cannot connect to xx: Connection refused". Ping works fine. The port from the Zabbix server to the host and from the host to the Zabbix server is opened (checked with telnet). The service is still running. The host has an installed Windows XP. There's another host with Windows XP where the agent is working fine. I can't find the difference between both config files. I reinstalled the Zabbix agent which had no effect. Why has the connection been refused?
edit:
Problem solved. Don't know why it happened, but port 10050 TCP was blocked. Only port 10050 UDP was opened.
edit:
