Zabbix Server Not Starting And No Logs
  • Singularity
    • Aug 2020
    • 81
    Zabbix Server Version : 4.4.10
    Database : AWS Postgres RDS
    One of my team members was performing maintenance on RDS. He didn't stopped zabbix server and neither has he setup maintenance window in zabbix.
    Problem Statement :
    1. After maintenance it was found that zabbix server went down
    2. No logs registered in /var/log/zabbix/zabbix_server.log to check what went wrong. Also no errors in syslog related to zabbix_server.
    3. When I checked the /var/run/zabbix/zabbix_server.pid file, it was missing.
    4. When I tried just to check if zabbix_server command is working or not with : zabbix_server -V
    In return I got
    Command 'zabbix_server' not found, but can be installed with:
    apt install zabbix-server-mysql
    apt install zabbix-server-pgsql
    What could be the possible reason that the file went missing and zabbix-server is not there ? Is this some sort of bug ?
    Thanks in advance.
  • tim.mooney
    • Dec 2012
    • 1434
    I'm pretty sure you answered this queestion:
    When you said this:
    In other words, your team member did something that inadvertently broke it. Maybe go back through that person's shell history, to see if you can spot any possible things that would have caused the package to be removed.
