Zabbix server is not running: the information displayed may not be current
  • modamer5
    • May 2021
    Dears ALL,
    I have successfully installed the Zabbix server, And I added some Switch to make sure everything was fine, After two days, I started adding all switches, including about 70 devices Through the Discovery Service, After that the alert message started to appear on the screen " Zabbix server is not running: the information displayed may not be current" and from System information Dashboard page, I see: Zabbix server is running Value NO.
    please i need some Help ...
    [[root@localhost ~]# systemctl status zabbix-server.service
    â—ڈ zabbix-server.service - Zabbix Server
    Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
    Active: activating (auto-restart) (Result: exit-code) since Mon 2021-05-03 12:33:00 EDT; 6s ago
    Process: 34972 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
    Process: 34968 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
    Main PID: 34970 (code=exited, status=0/SUCCESS)
    May 03 12:33:00 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:33:00 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    [root@localhost ~]# sudo tail /var/log/zabbix/zabbix_server.log
    34789:20210503:122824.948 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x37) [0x55e417cd104d]
    34789:20210503:122824.948 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0xaae) [0x55e417b2c122]
    34789:20210503:122824.948 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x2ff) [0x55e417cc18c1]
    34789:20210503:122824.948 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x2f5) [0x55e417b2b629]
    34789:20210503:122824.948 1: /lib64/libc.so.6(__libc_start_main+0xf3) [0x7fb82cb447b3]
    34789:20210503:122824.948 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x55e417b2a65e]
    34788:20210503:122824.952 One child process died (PID:34789,exitcode/signal:1). Exiting ...
    34788:20210503:122824.952 syncing trend data...
    34788:20210503:122824.953 syncing trend data done
    34788:20210503:122824.953 Zabbix Server stopped. Zabbix 5.2.6 (revision 798506596c).
    [root@localhost ~]# journalctl -xe
    -- Unit zabbix-server.service has begun starting up.
    May 03 12:28:02 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:02 localhost.localdomain systemd[1]: Started Zabbix Server.
    -- Subject: Unit zabbix-server.service has finished start-up
    -- Defined-By: systemd
    -- Support: https://access.redhat.com/support
    -- Unit zabbix-server.service has finished starting up.
    -- The start-up result is done.
    May 03 12:28:02 localhost.localdomain kill[34776]: kill: not enough arguments
    May 03 12:28:02 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:02 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    -- Subject: Unit failed
    -- The unit zabbix-server.service has entered the 'failed' state with result 'exit-code'.
    May 03 12:28:13 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:28:13 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 780.
    -- Subject: Automatic restarting of a unit has been scheduled
    -- Automatic restarting of the unit zabbix-server.service has been scheduled, as the result for
    -- the configured Restart= setting for the unit.
    May 03 12:28:13 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    -- Subject: Unit zabbix-server.service has finished shutting down
    -- Unit zabbix-server.service has finished shutting down.
    May 03 12:28:13 localhost.localdomain systemd[1]: Starting Zabbix Server...
    -- Subject: Unit zabbix-server.service has begun start-up
    May 03 12:28:13 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:13 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:28:14 localhost.localdomain kill[34783]: kill: not enough arguments
    May 03 12:28:14 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:14 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:28:24 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:28:24 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 781.
    May 03 12:28:24 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:28:24 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:28:24 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:24 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:28:24 localhost.localdomain kill[34790]: kill: not enough arguments
    May 03 12:28:24 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:24 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:28:32 localhost.localdomain sudo[34793]: root : TTY=pts/0 ; PWD=/root ; USER=root ; COMMAND=/bin/tail /var/log/zabbix/zabbix_server.log
    May 03 12:28:32 localhost.localdomain sudo[34793]: pam_systemd(sudo:session): Cannot create session: Already running in a session or user slice
    May 03 12:28:32 localhost.localdomain sudo[34793]: pam_unix(sudo:session): session opened for user root by root(uid=0)
    May 03 12:28:32 localhost.localdomain sudo[34793]: pam_unix(sudo:session): session closed for user root
    May 03 12:28:35 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:28:35 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 782.
    May 03 12:28:35 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:28:35 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:28:35 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:35 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:28:35 localhost.localdomain kill[34800]: kill: not enough arguments
    May 03 12:28:35 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:35 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:28:46 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:28:46 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 783.
    May 03 12:28:46 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:28:46 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:28:46 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:46 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:28:46 localhost.localdomain kill[34807]: kill: not enough arguments
    May 03 12:28:46 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:46 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:28:57 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:28:57 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 784.
    May 03 12:28:57 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:28:57 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:28:57 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:28:57 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:28:57 localhost.localdomain kill[34814]: kill: not enough arguments
    May 03 12:28:57 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:28:57 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:29:08 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:29:08 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 785.
    May 03 12:29:08 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:29:08 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:29:08 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:29:08 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:29:09 localhost.localdomain kill[34821]: kill: not enough arguments
    May 03 12:29:09 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:29:09 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:29:19 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:29:19 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 786.
    May 03 12:29:19 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:29:19 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:29:19 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:29:19 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:29:20 localhost.localdomain kill[34828]: kill: not enough arguments
    May 03 12:29:20 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:29:20 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:29:30 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:29:30 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 787.
    May 03 12:29:30 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:29:30 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:29:30 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:29:30 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:29:31 localhost.localdomain kill[34835]: kill: not enough arguments
    May 03 12:29:31 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:29:31 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:29:41 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:29:41 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 788.
    May 03 12:29:41 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:29:41 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:29:41 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:29:41 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:29:42 localhost.localdomain kill[34842]: kill: not enough arguments
    May 03 12:29:42 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:29:42 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:29:52 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:29:52 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 789.
    May 03 12:29:52 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:29:52 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:29:52 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:29:52 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:29:53 localhost.localdomain kill[34849]: kill: not enough arguments
    May 03 12:29:53 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:29:53 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
    May 03 12:30:03 localhost.localdomain systemd[1]: zabbix-server.service: Service RestartSec=10s expired, scheduling restart.
    May 03 12:30:03 localhost.localdomain systemd[1]: zabbix-server.service: Scheduled restart job, restart counter is at 790.
    May 03 12:30:03 localhost.localdomain systemd[1]: Stopped Zabbix Server.
    May 03 12:30:03 localhost.localdomain systemd[1]: Starting Zabbix Server...
    May 03 12:30:03 localhost.localdomain systemd[1]: zabbix-server.service: Can't open PID file /run/zabbix/zabbix_server.pid (yet?) after start: No such file or directory
    May 03 12:30:03 localhost.localdomain systemd[1]: Started Zabbix Server.
    May 03 12:30:04 localhost.localdomain kill[34856]: kill: not enough arguments
    May 03 12:30:04 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
    May 03 12:30:04 localhost.localdomain systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
