Moving from MySQL on Localhost to dedicated server...
  • macaulay
    • Oct 2014
    I've been using Zabbix for around a year now, monitoring around 90 hosts (2000 or so items). All has been fine until recently where the zabbix vm started running out of space.
    Long story short; i have set up a second MySQL only box to sit alongside the zabbix instance. I have transferred the db from localhost to the new box ( using
    mysqldump -u USERNAME zabbix > db_backup.sql
    and
    mysql -uUSERNAME -h NEW_MYSQLBOX -pPSWD zabbix < db_backup.sql
    and changed DBHost in zabbix-server.conf however i'm not seeing any new data?
    A suitable user has been created in the new DB and amended in the conf file. I can
    mysqladmin -u USERNAME -h NEW_MYSQLBOX -pPSWD status
    and connect to new db.
    Have I missed a step?
    Thanks in advance (all logs available by request).
    Mac
  • joergi
    • Jul 2013
    • 32
    Hi Mac,
    It looks like that you missed to change the $DB['SERVER'] in the zabbix.conf.php of the web frontend.
    Regards,
    Jörg
    • macaulay
      • Oct 2014
      That could be it!
      I only found references to that file from about 2009 so I assumed (#sound of open palm slappining forehead#) it was relevant to v1.8.x series...
      i'll have a look and report back...
      • macaulay
        • Oct 2014
        That was it.
        Thanks for the swift reply, here; have a picture of cat. It will appease the gods of the internet...
