Problem with docker-compose containers not starting
  • grumpazoid
    • May 2021
    Hi.
    I am new to Zabbix.
    I am trying do deploy with docker-compose using the following: docker-compose -f ./docker-compose_v3_alpine_mysql_latest.yaml up -d
    However not all containers are pulled / run e.g. no zabbix agent. My output is not that as shown in the docs.
    OS is latest Debian - I have tried on 2 different installs and the problem is the same.
    WARNING: The following deploy sub-keys are not supported and have been ignored: resources.reservations.cpus
    Creating network "zabbix-docker_zbx_net_backend" with driver "bridge"
    Creating network "zabbix-docker_zbx_net_frontend" with driver "bridge"
    Creating network "zabbix-docker_default" with the default driver
    Creating zabbix-docker_db_data_mysql_1 ... done
    Creating zabbix-docker_mysql-server_1 ... done
    Creating zabbix-docker_zabbix-server_1 ... done
    Creating zabbix-docker_zabbix-web-nginx-mysql_1 ... done
    What am I doing wrong?
  • grumpazoid
    • May 2021
    I have also now tried with Ubuntu server and get the same result?
    • bordwalk2000
      • Jul 2022
      I also have the same results. Not all the containers specified in the docker-compose file are created and I don't understand why.
      user@zabbix:/opt/zabbix-docker$ sudo docker-compose ps -a
      Name Command State Ports
      zabbix-docker_db_data_mysql_1 sh Exit 0
      zabbix-docker_mysql-server_1 docker-entrypoint.sh mysql ... Up
      zabbix-docker_zabbix-server_1 /sbin/tini -- /usr/bin/doc ... Up 0.0.0.0:10051->10051/tcp,:::10051->10051/tcp
      zabbix-docker_zabbix-web-nginx-mysql_1 docker-entrypoint.sh Up (healthy) 0.0.0.0:80->8080/tcp,:::80->8080/tcp, 0.0.0.0:443->8443/tcp,:::443->8443/tcp
      • Nosfy
        • Aug 2022
        I also face the same issue:
        All containers start, then after few seconds db-container ( does not matter is I try postgre or mysql ) exits with code 0 and logs for web say:
        **** MySQL server is not available. Waiting 5 seconds...
        Restart of container or setting it in restart-always does not change a thing.
        I do suspect something is wrong with db connection but have no idea how to figure our what exactly,
        Any help will be appreciated,
        Thank you.
        • Nosfy
          • Aug 2022
          Thank you.
          So this was gixed by changing network to
          internal: false
          And now I have issue with DB:
          Database error:
          Unable to select configuration
          Have to say that other colleagues of mine have no issues with pretty much the same config:
          - Hyper-V
          - Ubuntu Server 22
          - Latest Docker
          - Latest Docker-compose
